Siemens S7/TIA v18: Configuration control of projects?......
Mas01
Oct 2020
Leicester, England
1,109
General Question:
The PLC and HMI that I've been working on (a laser measurement system) is soon to be transported to the site where it will be used.
It will be Version 1.0.
How do I put the project into config control, so that I can keep track of further changes? e.g. an upgrade to version 1.1 then version 1.2, at some point in the future.
What sort of config control software do you typically use with TIA, or is there one built into the software somewhere?
TIA has a 'Version Control Interface' that can work with Github.
https://www.youtube.com/watch?v=gmTNIA9MhJk
I dont use it though.
We dont have a lot of people working on the same program. One person is the master programmer. If necessary another person can create a customer program from the master program but that is all.
We have a simple regime of always assigning a version no to programs, and always checking with the online PLC if it matches the offline program. If it does not match then something has gone wrong and it must be investigated before deciding what to do.
Thanks for this, @JesperMP. I'll have a look at that video.
I'm hoping I can keep the config control as simple as possible, as it's just me that does the updates, but could be someone else in future.
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi again, When the "REPORT" button is pressed (on a different screen), it takes the operator to the...
666
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi, The operator has reported that, from time-to-time, when he presses the "Generate Report" button...
463
Hi, I'm not sure how to do this... Basically, I want to restrict the user input values for this tag to be in the range 20.001 to 25.0. I...
17
1,632
Can someone help me with this? I'm no good at SCL - virtually everything I've done so far has been ladder logic. The return value from the...
1,107
Hi, Am I being daft (again)? I want to increment a tag (Integer) by 1 each time a button on the HMI is pressed. Before the button press, the...
22
2,361
