Accessing array of bools in Proficy Machine edition from quickpanel
smf
Jun 2006
Växjö
71
Hi.
I'm working on my first project with proficy machine edition (version 9.5).
Normaly i use Siemens equipment but now we're upgrading a pretty large system with a rx3i plc and quickpanel+ 12" panels.
The PLC program is running fine already as we pretty much just reused an old modicon program.
The old system lacked HMI interface so fault finding was quite time consuming for them when there was problems but we will add it now.
I just started to play with the Quickpanel and have problems when using bits in an array of bools in the plc.
It seems like i can not access them at all?
I have tried to insert the bools into different places but when simulating the panel i get question marks (?) over the button etc where i have used them and other bools works just fine.
For testing purpose i created one array tag with array dimension 1 set to 32 and array dimension 2 set to 0.
What am i missing?
The array of bools will be used to set alarm bits and show them on the HMI btw, if there is better ways to do it, please inform me.
Accessing the bools is working now for unknown reasons after doing another download or whatever i did :O
Hi, I am using Codesys 2.3 and I need to access some array elements within an array. I am reading a modbus device and populating the data into...
2,310
257
For the past few day, I have had problems accessing the Rockwell Knowledgebase. When I try to access it (and I do have a TechConnect Support...
430
Hi, Small issue i've really been beating myself up over today. I've been working with Panelview panels for years. Currently working on an older...
599
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,748
