Omron Sysmac C200H PLC + High Density Output Unit + Syswin 3.4 = Non-Recognition!
Tribochet
Feb 2004
We're having extreme difficulties getting the PLC to recognize the High Density Output Module (C200H-OD218). We're using SysWin 3.4 for programming and whenever we create teh PLC I/O Table...it only recognized the unit as an "Uknown Unit." Any suggestions?
Tribochet,
the number of group-2 high-density out-put modules is limited by the cpu model. Don't know if your using a slaverack or not but I don't beleive you can use these as a slave. Are you sure you have the correct setting on the modules. Let me know if I helped any, or what you found out.
Michael
If this is a C200H-CPU01, then it will not recognize the C200H-OD218 which is known as Group 2 I/O. The Group 2 I/O started in the C200H family at C200H-CPU21/31.
PLC omron C200H + touch screen
after 15 wears use in a machine we just found that we don't have any kind of back-up solution regarding the the "plc's programme".
i was start searching in google for any kind of software to help me backing-up the above plc's data.
Could anyone help me to have this step by step because here in greece it hard to find a person nowing this kind of stuf.
thank's in advance
babis
Our machines plc's are obsoleted. I cant get the programming cable to backup my plc. Pls help ,if any alternative cable or circuit available for...
2,650
how do i clear this alarm? i've changed the battery today, but i dont know how to clear the alarm. thanks for your help.
6,692
I took an online course but don't remember covering this. How do I access the system clock in a compare instruction? I want to turn on an output...
536
I come from an AB background. My current job has a lot of Omron devices. We have a couple systems with NX102's with numerous IO link devices...
675
Hi everyone, I am trying to program a function block to copy the variables obtain from Ethercat into a structure on a NX1P2. Since I cannot...
1,151
