Omron sysmac C200h cpu-01 ( memory in eprom block)
pulikutti
Jul 2010
singapore
21
Our machines plc's are obsoleted. I cant get the programming cable to backup my plc. Pls help ,if any alternative cable or circuit available for this Sysmac
C200H CPU-01
thanks
pulikutti
The C200H-CPU01 requires a host link module to connect to a computer. There were two different units, one was rack mounted like an I/O module, the other mounted to the front of the cpu.
The peripheral port on the front of the cpu will only support the handheld programmer.
Hope this helps.
how do i clear this alarm? i've changed the battery today, but i dont know how to clear the alarm. thanks for your help.
6,663
We're having extreme difficulties getting the PLC to recognize the High Density Output Module (C200H-OD218). We're using SysWin 3.4 for...
11,462
I took an online course but don't remember covering this. How do I access the system clock in a compare instruction? I want to turn on an output...
508
I come from an AB background. My current job has a lot of Omron devices. We have a couple systems with NX102's with numerous IO link devices...
652
Hi everyone, I am trying to program a function block to copy the variables obtain from Ethercat into a structure on a NX1P2. Since I cannot...
1,117
