Telemecanique Twido TO Twido Data Exchange (%MSG or EXCH?)
Andy S
May 2006
England
40
Hello all,
I need to get a couple of Telemecanique Twido PLCs talking to each other.
I need to send no more than 64 bits between each PLC.
After having a look through the help files it looks as though the %MSG function or the EXCH instruction could help me achieve this?
I'm continuing to have a look on the net but just wondered if any of you guys had any experience of this?
Hardware that were using:
2 * Twido TWDLMDA20DTK PLCs
DH485 connection that I believes makes use of Modbus protocol?
Any help will be greatley appreciated.
Many thanks
Andrew
I did some extensive messaging using TSX Premiums last year. From memory I tried both methods, and settled on the MSG because it was the first one I could get to work. Sorry I cannot help more, but I was so PO'ed by the whole Unity Pro experience I've deleted everything pertaining to it off my PC's.
Yes, two Twido can talk through Modbus ASCII (I don't know why RTU isn't supported by EXCH - RTU slave works). You must to use EXCH1 or EXCH2. %MSG only manages data exchange but cann't start communication. EXCH do it.
Port parameters must be configured for both PLCs before - Edit Controller Comm Setup (right click on port).
I reccomend to buy 2 TWDNOZ485T modules. Catalogue price of module is 34.29 EUR only. You can troubleshoot more suitable with it because Twido Port 1 will be free for PG operations.
Dear friends i Need pin out diagram of cable TSX PCX 1031 for Twido PLC.
5,224
Hi, i'm working on an already written plc program using twido that controls speed of a drive through an hmi (magelis). unfortunately, no...
3,198
Do any one of you have experience in TWIDO PLC on a burner management system application or any critical application like BMS ? I am looking of...
6,340
I am using Twido TWDLMDA40DUK in my application. I am confortable writing ladder logic in RSLogix500 and now trying to convert same logic in...
4,088
hello everybody!!!!!! how can I write a comparison for a counter on twido telemecanique plc my counter is the c0 , I try to turn on the internal...
3,913
