Display items in FactoryTalk View SE 6.10
Sep 2014
nc
60
This question deals with FactoryTalk View SE 6.10.
I am working on a project that will display different lengths of lumber product when commanded.
I will need the lumber to appear in certain areas when I type in the size.
I’m interested in making this a pull down selector.
Please help me out on this.
A little fuzzy on everything your trying to do but I think 6.1 has the "control list selector" on the toolbar to do a scrolling list (not necessarily a drop down). You need to use up down arrow functions to scroll through your list. This is good when you have preset sizes.
If you are always going to be changing things it might be better to use a numeric input box for size entry. May be other ways to do these also, these are just the ones I used and am familiar with.
I am being asked if I can put pictures on a regular PV+ screen. I feel sure there is a way if it were a Versa View CE, but I don't know if the...
2,218
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
129
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
173
Is there a way to add a local message display to Studio 5000 View Designer? If its there, I’m not finding it. I have used them in older versions...
409
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
146
