Rockwell Automation Light Curtain-Guardmaster 440C-CR30 Configurable Safety Relay
Cydog
Feb 2018
Maryland
313
Good Evening ,
I have some Rockwell Light Curtains and Guardmaster 440C-CR30 Configurable Safety Relays . I was wondering if there is any other Safety
Relays that Rockwell Automation has , that can be used with Safety Light Curtains . I would like to still use the muting , because it is for a palletizer application .
Thanks so much ,
I guess I should ask first why you can’t use the CR30 with the light curtains and muting?
Just , we have a very low skilled maintenance department, and I don’t want them to think that it is the program , or anything else . They can change out a safety relay , but when it comes down to the CR 30 , then it get complicated.
Good Morning , I was thinking of using a Guardshield Safety Light Curtain on a palletizer. The light curtain I was thinking of using is a...
1,090
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
105
Hello Guys, I am using 1769-L36ERMS PLC by Rockwell which doesn't let me MOV or COP literal text into string datatype? i very well know the...
409
Good Afternoon , Does Rockwell Automation have an Input Card , maybe in the 1734 series , or CompactLogix series that will receive signals...
883
Hi everyone, I'm working on a project that involves using a Keyence LR-X100 sensor in Studio 5000 V35 ladder logic to determine the object's...
699
