Forc LED on but no Response
Yes i have enabled the forces. I have attached pdf of what i am forcing. It shows force ON in software and it also shows LED light on on processor but things are not turning ON. Please help.
The pdf you posted does not show the output instructions. Can you post the .RSS file showing the forces? ( zip it first).
The .RSS file you posted does not have any forces.
Again what address(s) are you trying to force? Can you post the .RSS file with the forces?
The file you posted does not show any Outputs or Inputs forced.
You can only apply a Force to an Input (I:xx/yy) or an Output (O:xx/yy) bit. You cannot apply Forces to B, N, F, T, (etc) data file elements.
Right-click on the Output you intend to Force, and select "Force On" or "Force Off".
I have attached file with forces. If you go to ladder 8 rung 29, 30 and so on. All the rungs are showing force on software, even led light on processor but not turning ON.
When i did that it shows I/O configuration mismatch. The expansion I/O configuration in the user program did not match the actual configuration. When i see machine first thing is processor, than 1769-IA16,1769-OA16,1769-IA8I. I dont know why it says mismatch.
Sorry for my lack of knowledge, beginner here. Yesterday, we had a Pro-Face SP5000 HMI fail on us. The technician said that the HMI had the blue...
122
hello I have 7cp476 cpu why can led always open and No connection
131
Why AMIo800 Analog input module's I/O LED is Lighting up Red? Checked module connections, 4-20ma wires etc but this light is continuously Lighting...
112
Hi everyone, I got a Parker HMI, CTC PA2. I tried to download program to it but it froze in the process and could not finalize. Now, when I try to...
42
Hi all, I am trying to do Modbus communications via the CB1241 RS485 Communication Board on a Siemens S71200 PLC. I am using a 1215C CPU. After...
254
