Logix5000, ControlNet fault with code 16#0022 and 16#0203
wendaiyu
Jun 2014
toronto
87
Hi, folks, how’s going?
On our one production line, we use AB logix5000 as master PLC and Fanuc robs as slaves.
There is ControlNet fault with code 16#0022 and 16#0203 between Logix5000 PLC and one Fanuc rob.
From Logix5000, we can see the status of rob Controlnet keep doing “IO faulted, waiting, connecting, shutting down, standby, IO faulted, waiting…”
We checked the rob I/O connection, it was dirty and loose. We cleaned and tied it up. But still the same issue.
Could somebody give us a help to figure it out?
Thanx a lot.
i am facing problem with controlNet which communicating with Powerflex 700 drives. the communication is healthy with drives for certain time for...
1,980
Hello, I have a small controller rack with CPU (L61 ControlLogix) Ethernet (EN2T) and ControlNet (CN2R) module. This system will eventually be...
9,578
I need to read Drive status from 10 GV3000/SE drives. I am using ControlLogix processor @ V13.31 and the path is via ControlNet. I see plenty on...
3,674
Hello, I am going to cofigure a redundant control net network having total 5 nodes. One of the 1756-CNBR's is having one 1756-CNB in its...
17
4,893
Hello everyone, Wondering if anybody can help me with this: I have a CompactLogix processor running a little robot cell. Every 200 cycles...
173
