Omron CJ1M CPU11 Error that appears when i connect via serial port
Msobh
Mar 2018
Egypt
Hello,
I have PLC Omron CJ1M/CPU11, the problem is whenever i connect the PLC to my PC (laptop) via serial port and try to go direct online using cx-programmer either it fails to upload or the following errors occurs
b2_download_file_by_id
These errors only appear when the machine start working when the machine stops the errors disappear, this happens only when i connect via serial port. I tried connecting via peripheral port, no errors appeared which is kinda weird.
I tried changing the cable, it didnt work. Any help ?
Thanks in advance and have a nice day.
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
248
hi dear all hope you all are fine I have a problem with my CJ1M cpu11 ETN. it stop communication with PC over ethernet. ETN unit all indications...
169
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
161
Hey, new to Omron. I have a CJ1M CPU11 PLC that I need to connect to and backup. When I look up Omron programming software, I find three different...
1,679
Hi everybody, I can't transfer data from laptop to omron sysmac cj1m cpu11. I use cable "omron cs1w-cn118" and Uport 1150 (RS232),I sure software...
3,915
