Industrial ethernet & Profinet difference
profinet is acombination between ethernet and profibus
the main advantage in profibus over ethernet is that has priority
for ethernet u can not set priorities so an order to a drive could be delayed if someone is sending an email for example and thus u can not guarantee real time communication
with profinet u have all the advantages of both profibus and ethernet
Is there any difference between Profinet and Industrial Ethernet ? Same hardware is used for both ? Same softwares ? Thank you
17
6,615
What's everyone using for their wireless ethernet radios? Just for a couple remote 1794flex racks a couple city blocks away. We've used Esteem in...
915
Kindly, we have a huge stock of the following encoder cable. Is it possible to use it for industrial Ethernet connection also? (automation and...
2,078
Hello, first time poster. I've been tasked with designing an industrial Ethernet network with about 200 nodes. I'm struggling with setting up a...
3,033
I am starting a project to upgrade our building utility system. The actual swap out will be done by outside contractor. The new system is IP...
17
4,744
