signal cable for industrial Ethernet ?
Kataeb
Jan 2007
www.livelovelebanon.com
636
Kindly, we have a huge stock of the following encoder cable. Is it possible to use it for industrial Ethernet connection also? (automation and drives communication on machines)
{ 6FX8008-1BD41-6AA0 , Siemens , Signal cable sold by the meter type: 6FX8008-1BD41 3x (2x0.14) C+4x 0.14+2x0.5 C MOTION-CONNECT 800PLUS trailable, UL/CSA, DESINA Type of delivery: Disposable drum Dmax=9.2 mm Length (m)=500 }
Thank you
hello guys, I wonder if I can connect a 4-20ma signal in a multiconductor cable when the other conductors is primary used for control signal...
1,489
A bit off topic, but I have an old heat trace controller where they used the power cable to get the rtd reading. They have lil pc board at the rtd...
2,013
Hi, Can I have genius thoughts on if there will be any concern if I run RS-485 2-wire cable with Analog input in one multicore cable lets say...
3,530
Hi everyonr, i am trying to load the driver for my signal cable,USB-1761-CBL-PM02, a usb interface cable for AB PLC, but the LED didn't light, and...
1,424
Perhaps I am asking my suppliers the wrong questions, but I need some sort of flexible cable for a 4-wire RS485 application. It is a Class 1 Div 1...
2,724
