s5 splitting segmant to be veiwed as ladder from stl
craig61
Oct 2003
hi
does anyone out there have an easy way of splitting none translatable segmants in s5 so i can veiw them as ladder for easier use by ab users i understand some still will not be able to be veiwed as ladder, but i would like to see if i can do as much as possible so i was wondering if there is quite a quick way of doing it.
thanks
carig
Craig,
what Seppo means is that BLD255 is the instruction which marks the end of every network. You insert a new line in the STL program where you want to split and subsequently put BLD255 in that line. Three asterixes should do as well.
The way I see things: if you need to do this, then the program was poorly written to start with. I always tell my trainees to write as much as possible in ladder. That way you're not stuck to Siemens (as ladder is much less brand-specific), more people can read your program and nobody has to do the dirty work of adapting the program as you have to do now.
Kind regards and good luck,
I am close to wits end and would appreciate any new perspective. Cannot go into minutia, but here is a rough rundown of the system and issue we...
26
9,346
I have to take a 16 bit N register and split some of the bits into separate integers. example: Bits 0-1 = integer with a value from 0-3 Bit 2 is...
22
5,953
Would it be wise / safe to split a 24vdc input from a switch to a PLC and relay? I currently have 14 of the same type of equipment that each have...
1,547
Any one know of way to split a 4-20 mA signal 4 ways? Do they even make such a device? Thanks
3,671
I have an application where I need a single SSI encoder to connect to both a safety controller (SICK Flexi Soft) and a general-purpose PLC...
2,123
