plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 12th, 2016, 07:47 AM   #1
ndzied1
United States
ndzied1 is offline
ndzied1's Avatar
Packing Data Into a Tag
I received this via PM but am re-posting it here so all can see.
Note that there is only 1 word available to pack this data and only 15 bits of the word can be used.
My suggestion is in the attached PDF file. Resolution is pretty low but if you have to do what is asked, "pack 4 pieces of data into 15 bits" of course it will be low.
Quote:
I need to be able to encode/mask and decode the values of 4 PLC tags being written to the RFID Tag.
So if I have four PLC tag values that I need to put on the RFID tag for example:
Tag 1 (35.3)
Tag 2 (400.1)
Tag 3 (75.4)
Tag 4 (112.7)
The sum total is 623.5 since the RFID tag can only hold a 16 bit integer value. I can multiple it by 10 and that's 6235 I can write that value on to the RFID tag no problem I can get that far.
It's when the RFID tag passes another reader and it reads a value 6235 I can divide the value by 10 and bring it back to its original value of 623.5 but I need to be able to decode that value and know that it is comprised of the following:
Tag 1 is 35.3
Tag 2 is 400.1 and so on
That's the problem I'm having decoding the RFID tag when it passes another reader, if it displays a value of 6235, it means nothing to anyone else but me as I know that the value comprises of four PLC tag values.
So what I'm asking is there a method of decoding the sum total and retrieving the original four PLC values solely using Codesys to convert the sum total 6235 back to the original 4 PLC values.
Apologies I haven't been clearer it hasn't been easy from your point of view as I have kind of said the same thing to you twice regarding arrays when arrays are not the issue.
I can post the thread in the forum no problem it's just a very specific issue and if you're busy that's no problem either.
I was just looking for an opinion on how to approach this.
Thanks for your help
My answer to this problem is in the attached PDF file. Note that the values in my pdf file for the range of each piece of data came in a prior PM to me.
__________________
nOrM
nOrM=Norman Dziedzic Jr.
I've never been to China but my phone has.
Last edited by ndzied1; January 12th, 2016 at 07:52 AM. Reason: additional information for clarity.
Old January 12th, 2016, 09:41 AM   #2
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
Nice approach.
Was the resolution OK with the application?
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old January 12th, 2016, 12:16 PM   #3
ndzied1
United States
ndzied1 is offline
ndzied1's Avatar
Quote:
Originally Posted by gclshortt View Post
Nice approach.
I think so. He seemed pretty happy but not sure the lack of resolution has set in yet....
__________________
nOrM
Old January 12th, 2016, 01:11 PM   #4
KalleOlsen
Norway
KalleOlsen is offline
What about using bit 0 and 1 as index 0-3, and use bit 2 to 14 as value holder?
More complicated, better resolution.
Kalle
Old January 12th, 2016, 01:16 PM   #5
gclshortt
Canada
gclshortt's Avatar
I was thinking the same thing kalleOlson but:
This is on a TAG.
Regards,
__________________
Garry
Old January 12th, 2016, 01:34 PM   #6
ndzied1
United States
ndzied1 is offline
ndzied1's Avatar
Just to confirm, Garry is right. Sorry if it was not obvious. The request was to pack 4 pieces of data into an RFID Tag with only 15 bits available.
__________________
nOrM
Old January 12th, 2016, 01:38 PM   #7
GaryS
United States
GaryS is offline
GaryS's Avatar
I don't believe what you want to do is possible
you have 4 4 bit words to work with binary value of 4 bits = 0-15
all1"s would only yield 15 15 15 15 split out the way you show
I don't see any way to make it work just adding the values together will not work because you have no way to separate then without knowing the values before hand.
you may have to pick 2 of the 4 values that will give you 2 8 bit words each word = 0- 255 you may be able to work with that
Old January 12th, 2016, 01:45 PM   #8
ndzied1
United States
ndzied1 is offline
ndzied1's Avatar
Oh, I'm sure what I presented will work as advertised. Whether or not the OP can live with the super low resolution I have no idea.
__________________
nOrM
Old January 12th, 2016, 02:22 PM   #9
widelto
Colombia
widelto is offline
widelto's Avatar
Norm: Simple but efficient
__________________
My two cents.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Understanding RSLogix5000 I/O Base Tag Addressing Structure blanchsb1 LIVE PLC Questions And Answers 9 October 16th, 2015 07:42 AM
Reading data block from plc to a tag in wincc karofilakis LIVE PLC Questions And Answers 7 September 30th, 2014 11:29 AM
crimson redlion g3 data tag scaling kashifidrees LIVE PLC Questions And Answers 3 May 14th, 2013 07:58 AM
Help with Profibus CPU315-2 DP Rafael Guedes LIVE PLC Questions And Answers 5 September 3rd, 2007 07:44 AM
Data to STRING tag at startup JERA LIVE PLC Questions And Answers 2 July 31st, 2007 10:21 AM
