RSlogix - Packing Line
Is there anyway to represent properly a N/O STOP button in RSlogix (I hope I am not getting confused with terminology here... sorry if I am).
A PLC instrcution for a Normally Open STOP button (if one existed) would be an XIO and look similar to a NC contact, but a PLC instruciton for a typical Normally Closed STOP pushbutton looks like the XIC instruction (an open contact). In other words, you use the opposite-appearing instruction for both cases (if anyone did ever mistakenly use a real N.O. STOP button).
First, you need to make a big adjustment in your thinking. The Input instructions in your ladder logic do not and were never meant to represent the actual appearance of the physical device that is sending the input. They only represent how YOU want the program to interpret the signal from the physical device. Once you adjust your thinking like this:
"The PLC input instruction XIO does NOT a produce a copy or clone of the state of the physical device", but rather its inverse.
Then you will not have any more problems with this part. You can do a site Advanced Search look back at old posts. That topic has been discussed on this site too many times to count, and probably will be talked about here forever, as long as PLCs exist in their current form.
Does that mean I have to force it in order to have my simulation on a PLC software working normally?
If your simulation software allows you to use a XIO for a STOP pushbutton, then it has a severe error in its program! I would think twice about this software, if indeed that is the way it is. Does your simulation software also allow you to set the type of physical pushbutton? If so, perhaps you do not have your physical button set up to have a normally closed (N.C.) momentary contact. Stop and Emergency Stop buttons should have NC contacts, while Start buttons should have NO contacts.
Thank you for the info i got it.
Greetings, I need to move various bits from a tag TO_SEND (type = SINT[20]) to a consecutive order into bits 0-15 of a tag = SEND (type =...
4,569
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
156
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
168
