RSLogix Emulate 5000
akreel
Apr 2002
Milwaukee, WI
1,172
I hope someone here is familiar with Emulate. We're having some interesting complications, which I'll try to describe. Has anyone tried this before?
Background
The logic we are attempting to simulate contains a subroutine call to a standard function block. The function uses its own internal (program scoped) tags to run its logic. Each instance (we are currently only testing one) is passed all the data from a global tag of the same data type used in the subroutine. The results are then passed back to the global tag. Essentially, the subroutine is being used as a user-defined function block. We have no trouble with these "function blocks" when we run them in a CLX CPU.
Problem
When we run the same function blocks in emulate, the data seems to be periodically reset. For example: there is a self-maintained output coil in the routine which will periodically (every 9 seconds or so) decide to drop out. We have discovered that the "ON" condition for the output is being reset, which of course causes the coil to drop out.
I wrote a simple test, using a NO contact (TAGXXX) and a coil (also, TAGXXX). If TAGXXX is one of the tags passed into the subroutine, it will periodically drop out. But, when TAGXXX was not one of the data members being passed into the routine, the coil would hold indefinately (as it should).
I hope my explanation makes sense! Am I crazy? Has anyone seen this?I've checked for all the obvious stuff: dual-use coils, memory overlap, etc. I've dumbed down everything to the point where I can say this has to be an issue with Emulate. Of course, our on-site Rockwell support is going to hear about this, too.
AK
NEVERMIND!
It was an IO (idiot operator) problem. The guy who wrote the code went back and found some buried logic. But, I'm still not 100% sure why the simulator was behaving the way it did. The solution doesn't really fit the symptoms...
Oh well, I guess we'll just put the horse blinders on and move along!
AK
Respected Members I try to install RSlogix Emulate Version 20.04.00 but the error occurs during the installation which is shown in the image...
984
I have RSLogix Emulate 5000 v21. How upgrate it to v31?
1,126
I want to to communicate a panelview plus with an RSLogix emulate 5000 and I know that this is not possible by RSLinx Enterprise, how can I do it...
2,770
I have an existing Compac Logix program and I would like to run it using the RSlogix 5000 Emulator. is it Possible can some bocy give me directions?
2,300
We’re looking to setup a stand-alone training station with FT View and a connection to a simulated plant system which would match the RSLOGIX 5000...
3,787
