plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 8th, 2017, 01:48 AM   #1
Engrtalha
Pakistan
Engrtalha is offline
Simovert Master Drive -Profibus Enabling Running Problem
Experts!
Need Help
In My application i have Siemens CPU 316 WITH APPROX 28 PROFIBUS NODES (including Simovert Master Drive -14N.o.s & IM153 & Et200 Module).There are 02 Drives which are running with Single slection from HMI and drive were running normally for weeks but sudden 01 SImovert Master is creating Problem after Enabling.
Problem Detail:Normally drives shows P008
and after enabling one drive is running normally(5.4 Hz approx) while other is showing some values for 1-2 second on Drive Display & slight Motor Movement Physically then stuck or showing 0.000 on display ,mean while other drive is running normally.
Kindly guide me what would be the possible cause for this Drive response problem stuck on 0.000 while other Motor is running.
Task Atempted:Re parameterize drive again but status is same
Changed CUVC card -Reparameterize -Status same
Checked Profibus shield Grounding -OK
Checked Drive Power DC Link -OK -Motor Check OK
Plc status: normal no bus/Communication failure.-Online Status
Drive status Normal
Drive Model #:6SE7023-8TD61-Z
Communication card :CUVC + CBP +T100
Siemes CPU 316
Attached Simover Mster Drive Wiring Diagram
System Topology-Profibus nodes.
File Type: pdf Simovert Master Drive Wiring Diagram-3.pdf (285.0 KB, 18 views)
__________________
LEARN AS IF YOU HAVE TO LIVE FOREVER
Projects we have completed demonstrate what we know - future projects decide what we will learn
Your most unhappy customers are your greatest source of learning.
Old June 8th, 2017, 11:11 AM   #2
sigmadelta
Canada
sigmadelta is offline
Check the parameter values in the fault/alarm area, and check that your T100 software is indeed activated. Search in the manual below for fault/alarm, and T100.
https://support.industry.siemens.com...13277&lc=en-WW
__________________
Freelance Automation Programmer
Old June 8th, 2017, 11:32 AM   #3
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
Can you rotate the motor manually with the drive disabled?
Old June 8th, 2017, 01:26 PM   #4
Mad_Poet
United States
Mad_Poet is offline
Can you swap the two motors and see if the problem follows the motor?
Or, swap the two drives and see if the problem follows the drive?
MadPoet.
Old June 8th, 2017, 10:13 PM   #5
Engrtalha
Pakistan
Thanks for your support
__________________
Old June 9th, 2017, 06:39 PM   #6
JRW
United States
JRW is offline
JRW's Avatar
Get it working?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
DC Drive problem MartinW LIVE PLC Questions And Answers 6 April 11th, 2011 03:25 AM
Profibus drive krome LIVE PLC Questions And Answers 2 February 17th, 2009 07:46 AM
Simoreg DC Master drive Profibus configuration krome LIVE PLC Questions And Answers 0 January 13th, 2009 04:27 PM
S7 300 & LENZE DRIVE ON PROFIBUS nehe bhimaji LIVE PLC Questions And Answers 10 June 22nd, 2008 04:14 PM
Abb Ac Drive rajendrad LIVE PLC Questions And Answers 13 November 5th, 2006 10:18 AM
