simovert master drive
roxtech
Mar 2008
Township Lahore
198
Hi Drives experts,
we have 32 Siemens master drives runing on profibus with S5 155U on Im308c. Now one drive 37Kw 6ES7027-2ED20 runing with CU2 and CB1 card became faulty. we Have another Spare 45KW (6ES7031-2EE20) Drive. we installed 45KW drive inplace of 37Kw drive, we installed CU2 and CB1 card. with drive monitor software we reset parameter, change MLFB no. and download old parameter file to drive, then change profibus address and then fix profibus. drive give OK status. Then we started with profibus it run ok. after some time two diffrent dive on this profibus triped with F082 (communication fault). we try it two time but same result while profibus address is same as before.
Please Help me why is it happen?
Regards,
__________________
Zahid Ali Khan.
Rox Tech Engineering.
Township Lahore,
Pakistan.
cell# 0092-300 4608350
Most likely after setting the Profibus parameters online you haven't 'saved' them.
It's been a while since I've used it, but as I recall from using the "Drives ES" software on Siemens drives, It was one operation to set the parameters on the drive and another operation to 'save' the configuration to the flash memory on the drive. If you didn't do this then it would revert back to prior saved configuration when power goes off.
Experts! Need Help In My application i have Siemens CPU 316 WITH APPROX 28 PROFIBUS NODES (including Simovert Master Drive -14N.o.s & IM153 &...
4,867
Hi Dears, I am doing a project master drives CU2 To CuVC convertion. When I connect with Old Cu2 card with drive monitor it give me error...
1,485
Hi, i need to connect to a simovert VSD through profibus to compact logix 1769 l35E. What is involved in this process. do i need to change any...
2,400
hi friends, we have master drive 6SE7026-0TD20 with DC unit 6SE7028-6EC85-1AA0. our inverter become faulty(6SE7026-0TD20). Question is Can we...
1,896
My Dear Siemens professionals Funny question may be but can anybody give me a clue regarding two different types of frequency invertors which...
5,026
