plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 31st, 2018, 10:32 PM   #1
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
RSLogix 500 Version 10 Crashes when closing
I am running Windows 7 Pro 64 bit on a Dell Latitude laptop. Every time I close an instance of RSLogix 500 I get a pop-up:
RSLOGIX 500 DEVELOPMENT ENVIRONMENT HAS STOPPED WORKING
VERSION 10.00.00
Problem signature:
Problem Event Name: BEX
Application Name: Rs500.exe
Application Version: 10.0.0.0
Application Timestamp: 563b0b7a
Fault Module Name: MSVCR90.dll_unloaded
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4dace5b9
Exception Offset: 7389cf5e
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Read our privacy statement online:
http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
It seems to work fine and save files fine, and I usually have multiple instances running which scared me at first because I was unsure if the instance I had working with online edits had crashed or the instance I had just shut down.
You guys can probably help me find the answer quicker than searching the knowledgebase.
Thanks in advance!
Paul
I am running RSLinx Classic Lite version 3.71.00
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old January 31st, 2018, 10:36 PM   #2
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Hi Paul
How about Windows updates? They have been killing me with RSLinx
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, Fluke Meters, MicroLogix, ControlLogix, Siemens, Allen Bradley and more... all your automation needs... ((NEW)) After Market 1784-U2DHP Allen Bradley USB to DH+ and Gateways
Old January 31st, 2018, 10:38 PM   #3
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Quote:
Originally Posted by geniusintraining View Post
Hi Paul
My partner running Windows 10 got bit by this. I have not updated Windows since Jan. 10. But that is a good suspect.
__________________
Old January 31st, 2018, 10:46 PM   #4
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
More info:
It only happens if I have more than one instance open. I just did this without ever opening a file, just two instances of RSLogix 500 opened at the same time. I close one of them and get the error. Closing the other instance did not generate an error. RSLinx is not running when this happens.
__________________
Old February 1st, 2018, 07:38 AM   #5
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
I have the same thing happen if I close a window of Internet Explorer with more open.
But in this instance it causes the open windows to reload their pages and they show a warning that 'a problem with this webpage cause IE to close and reload the page'
__________________
Never underestimate the quality of idiots that will be running your machines
http://aabeck.com
Old February 1st, 2018, 03:13 PM   #6
James Mcquade
United States
James Mcquade is offline
Have you tried to do a repair of the installation from the control panel > programs and features?
james
Old February 1st, 2018, 07:28 PM   #7
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Quote:
james
No. I have just been clicking "Close the program" each time it happens, although the program appears to already be closed. Now that I know it is not causing any real functional problems, I have not aggressively tried to solve it.
As soon as I am caught up I will drill into it...right after I clean and organize my truck, get a hair cut, finish the tile in my bathroom...all those things I am planning to do as soon as I am caught up...
__________________
Old February 2nd, 2018, 07:55 AM   #8
jstolaruk
United States
jstolaruk is offline
Version 11 is available - I just opened (2) instances with no projects loaded in Win 7 Pro 64-bit with no issues. (Not virtual environments).
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Rslogix 500 version ?'s MacSnoogins LIVE PLC Questions And Answers 9 February 22nd, 2016 05:31 PM
RSLogix 500 emulator communications question robpaige LIVE PLC Questions And Answers 5 June 13th, 2013 10:31 PM
RSLogix 500 (Version 8.4.XX) & Windows 7 64 Bit burbrink LIVE PLC Questions And Answers 6 November 9th, 2011 11:27 AM
RS logix 500 version 7 and 8 jamalshahid LIVE PLC Questions And Answers 10 August 18th, 2011 07:13 PM
RSLogix 500 Vs. RsLogix 5 mrdmrd LIVE PLC Questions And Answers 7 February 21st, 2005 06:11 AM
