![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: Sep 2017
Ideas for safety barrier between 2 movable parts of a machine
I have a few machines that need a safety barrier between 2 movable parts of a machine. The angle changes and the gap opens up from 10 ft to 14ft.
See attached photo, yes i am an artist.... |
#2 |
Looks a lot like a machine I worked with in a tire factory. They used a cage with some sections on wheels and a couple of pivot points. There was a "man-door" with a safety switch. It was simple and effective.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants. |
#3 |
Most of the places where safety barriers are required that I have seen use a physical barrier with a switch in the e-stop circuit. They are switches specifically designed for the purpose. Allen Bradley, and others make them.
Barriers are often made with expanded metal welded to an angle iron-frame. Some are mounted with hinges so they can swing open, others are bolted up. In the United States, there are federal OSHA rules for barriers so I suggest you get someone involved in this familiar with the requirements.
__________________
Caspian --------------------------------------- 1+1 = 3 and I never was good at math. ---------------------------------------- |
#4 |
![]() ![]() Join Date: Jun 2007
A steel cable and this:
http://download.schneider-electric.c...EN%20(web).pdf using an NC + NC model can be inserted into the general emergency stop circuit Last edited by lfe; February 7th, 2018 at 09:39 AM. |
#5 |
![]() ![]() Join Date: Dec 2004
With the changing distance, a light curtain would be the first choice I would look into. You could hard fence the first 10 feet.
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen |
#6 | |
Quote:
A light fence is a great idea, I have seen those used quite a bit. The cable idea is nice but won't pass the specs if anyone can crawl over or under it. They have gotten to the point of ridiculous in some instances as to the requirements. A light fence provides a lot of flexibility so can be easily moved to accommodate changes.
__________________
#7 |
If the the light fence is mounted on a moveable part of the machine it may create a challenge to keeping it aligned.
__________________
#8 |
Yeah, but I've been in a plant twice when someone was killed by equipment; one by a robot the other by a press. So I understand where management tends to go what seems like extremes.
__________________
#9 | |
Quote:
It took an hour or more and Yep Three people to change that light bulb. 1. Get a Confined Space entry Permit. 2. Get an Air Sample 3. Put on a very cumbersome safety harness. 3. Get someone big enough to hull me out with the rope attached to my harness if I was overcome by contaminated air. 4 get someone to act as A safety watch. The pit was only 5 ft deep, about 10' wide x 20' long. Who knows what they would have done if I actually passed out and got hung up on something preventing them from dragging me out.....
__________________
#10 | |
Quote:
One place I worked, we caught a guy with a wooden stub fastened to his left leg using it to push a button on a two button press control so he could work faster operating the press. It was a Piece rate shop. He had quite an interesting rhythm operating the press with one hand and his leg.
__________________
#11 |
Safety cable def wont work with our safety standards today.
We have machines that have hard fencing with pivot points and wheels. They work, until they get hit by tow trucks/fork trucks. We have a couple machines that use a retractable cable to keep 2 pivoting photoeyes aligned. They work, ok, BUT they really do not want us putting that on any more machines... I thought about doing the same thing with light curtains... Thanks for all the input, I was just wondering if there was something on the market I wasnt aware of. |
#12 |
Would a safety floor mat work?? Those are made in a lot of different sizes.
#13 |
![]() ![]() Join Date: Dec 2012
You might look into a programmable safety Scanner like the one they use on autonomous fork lifts.
#14 |
Safety Mat or Scanner are very good choices. Scanners have some way down in prices due to competition.
__________________
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
"WET" Contact / "DRY" Contact | Terry Woods | LIVE PLC Questions And Answers | 20 | June 6th, 2010 08:15 AM |
Machine monitoring PLC, HMI, SMS text ideas | tacm | LIVE PLC Questions And Answers | 1 | July 14th, 2008 10:31 AM |
A-B plc5 tracking parts thru machine | tom_stalcup | LIVE PLC Questions And Answers | 4 | October 31st, 2005 10:54 AM |
Machine Safety: Pausing Index Table? | chakorules | LIVE PLC Questions And Answers | 23 | May 24th, 2005 02:09 PM |
One PLC, One machine V's One PLC, Two Machines | Mylo | LIVE PLC Questions And Answers | 13 | March 4th, 2005 05:38 AM |
