plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 7th, 2018, 02:48 PM   #1
golftmd13
United States
golftmd13 is offline
automatic fill/drain tank
I'm new to PLC's and I'm working through an exercise to manually control filling and draining a tank which I completed but the automatic function has me stumped. I know the limits and can get the tank filled and drained to the levels but I can't figure out how to open and close the "valves" automatically when the certain levels are reached. I'm working on Rockwell software. Any help is greatly appreciated.
Old February 7th, 2018, 03:36 PM   #2
tarik1978
Morocco
tarik1978 is offline
First welcome to the forum
Which PLC are you using?
Can you post a screen shot of your code?
Old February 7th, 2018, 03:59 PM   #3
James Mcquade
United States
James Mcquade is offline
May I suggest the following.
draw a sketch of your system.
sketch the level control limits and other devices in place. just a rough sketch.
1. Now, what do you want it to do? what were you asked to do?
Write it down on paper. these are the customer specs.
2. Write out what you want the system to do - forget the I/O locations,
just write down what you want the system to do.
3. go through what you just wrote and write in hi float switch, start pb, motor 1 starter, and so on. Don't worry about the I/o locations.
4. repeat step 3 again, this time, walk through the process as if you are the plc. think through each step in detail. Does it make sense?
5. assign addresses to your devices.
6. write the code.
it's going to be hard at first, but gets much easier in time.
regards,
james
Old February 7th, 2018, 04:55 PM   #4
NetNathan
United States
NetNathan is offline
Sooo...you have level switches on the tank for proper levels and you want to automate the use of the switches using valves for fill and drain?
__________________
****Control Freak****
Net is where I be and Nathan is me.
Old February 7th, 2018, 07:32 PM   #5
Mickey
United States
Mickey is offline
Mickey's Avatar
Some good reading...(learning)
http://www.plcs.net/chapters/example10.htm
The whole series..
http://www.plcs.net/contents.shtml
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old February 8th, 2018, 08:22 AM   #6
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
http://accautomation.ca/plc-programm...process-mixer/
The above post may help you out.
Regards,
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Flow Control On Tank Without Many Inbound Signals SilverShotBee LIVE PLC Questions And Answers 43 August 5th, 2016 10:04 AM
Cylinder Tank Cubic Meter calculation zai_jnr LIVE PLC Questions And Answers 3 June 11th, 2015 10:15 PM
STUDENT QUESTIONS, please post them here! Lancie1 LIVE PLC Questions And Answers 58 February 6th, 2015 07:16 PM
Help on re-filling tank automatic!! hrohibil LIVE PLC Questions And Answers 6 January 6th, 2009 10:45 AM
Analog Output follow up BoxerBrats LIVE PLC Questions And Answers 33 March 22nd, 2005 12:00 AM
