plc storereviewsdownloads
Go Back - Interactive Q & A > - Interactive Q & A > LIVE PLC Questions And Answers
PLC training tools sale
Thread Tools Display Modes
Old February 22nd, 2018, 09:55 AM   #1
United States
locotumbler is offline
Micrologix 1200 sticking relay
I have an issue on a system i've inherited. I had one of my relay outputs sticking on. When the lights off and i'm still getting voltage through it and I tap on the unit itself it releases. I thought initially since the system was around 9 years and over 5 million cycles that it simply failed. I replaced the PLC and had no issues for about 50k cycles, with the way we are running it now is like 3 days, and the relay started doing the same thing. It is running a small solenoid valve. I moved the output to a different unused output but on the same COM supply and had the output itself run an ice cube relay. I was gone yesterday and come in today to find out it started doing the same thing.
the system is running 24vdc through the relay. Any ideas on where I might start a deeper inspection into this? Could it possibly be getting back-fed from somewhere else on that COM?
Thank you in advance.
Old February 22nd, 2018, 10:22 AM   #2
United States
g.mccormick is offline
If it is actually relay output, it's probably due to voltage spike from connected coil. Put in a flyback diode across the solenoid to extinguish voltage spikes.
Old February 22nd, 2018, 10:46 AM   #3
James Mcquade
United States
James Mcquade is offline
relay outputs have a lifespan before they fail, look at the specs of your system.
I had the same issue, and eventually had to go to a triac output.
in your case I would go with solid state dc outputs and also do as suggested.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Micrologix 1200 PTO relay debouncing jderou LIVE PLC Questions And Answers 15 February 7th, 2014 08:25 PM
Micrologix 1200 , faulting Viking03a LIVE PLC Questions And Answers 14 March 5th, 2012 12:24 PM
micrologix 1200 relay output? matlark LIVE PLC Questions And Answers 5 July 12th, 2011 03:04 PM
MicroLogix 1200 & PowerFlex 70 csanchezs LIVE PLC Questions And Answers 4 July 24th, 2008 04:43 AM
micrologix 1200, and 1000 question darrentpi LIVE PLC Questions And Answers 4 July 24th, 2008 04:42 AM
