Variable Speed Magnetic Vibrator
ds7891
Sep 2016
Las Vegas
77
I need something to vary the speed of a magnetic vibrator.
It's 120vac Single Phase, 60HZ, 0.5amp.
Need something I could give a 4-20ma signal to so speed can be adjusted via PLC.
Can't use a door/device mounted POT.
I don't have a ton of space in the cabinet either. So something small.
Any idea?
A very simple dimmer is enough, as you do not need to control the speed, but the power.
Even a simple variac is enough.
dear all.. i am designing the Sea Water Intake pump which the 4 pumps will be operated parallel, and 1 pump will be as stand by pump The pump data...
157
We have an application where we need a joystick to control a VFD. Off in the center, 0-10V in forward and 0-10V in reverse. Also with auxiliary...
2,317
I have a customer that came to us, looking for a variable speed control for a 115V motor He bought a 115V vibrator. The motor is a cap start...
1,881
Repeat Question - Maybe to our UK friends, especially. I need variable speed control of single phase blower motors, for an OEM I work for. I...
3,621
Does anybody have any experience/suggestions for variable speed control of single phase motors? My application is: Control up to 4 - 1/2hp fans...
20
6,702
