Optimization of parallel variable-speed-driven centrifugal pumps operation
rudiawan
Mar 2024
jakarta
dear all..
i am designing the Sea Water Intake pump which the 4 pumps will be operated parallel, and 1 pump will be as stand by pump
The pump data as follows :
Type : vertical turbine pump
Flow : 5000 m3/hr
Head : 20 meters
Electric Motor : 2500 KW, the motor provided with VSD (variable speed drive)
The operation pump speed at normal condition is 740 rpm
I am developing to prepare the operation procedure for the pump operation, may i get the advise how to ramp up the pump speed parallel and safely, from 0 rpm to operation speed (740 rpm)
your advise will be appreciated
regards
rudiawan
Log your run times on all motors
Stager the run hours the last thing you want the 5 of the motors with about the same high hours and failing about the same time
Make sure you install isolation valves on each pump so if you have a failure you can pull it out while the others keep running
I had a client that didn't and they had a failure and they had to run for about 8 months with no backup until they could shut down for the yearly maintenance
Getting the run times spread out takes time but it could save you major failure later
I have a remote i/o rack that until today was only digital i/o. I am in need of adding some analog io to this rack. The control net card for this...
1,142
On old Siemens 300/400 series memory was usually saved if code was writed with ST or SCL instead of FBD or ladder. Now I tryed this with TIA /...
4,407
I read that using rack optimization a single CIP connection will be used to transfer IO data from remote card to local card, provided its a...
1,962
Please friends, I'm researching on 'optimization and automation of cooling tower using PLC'. I need a PLC program to automate the cooling tower...
4,372
Does anyone has any experience in designing operator consoles for a gas plant? How many operator consoles will be required for a process area of a...
1,930
