Hi, can someone help me elaborate more on the AB Ladder logic project attached below
nyameephraim
Apr 2016
dubai
29
Hi, i uploaded program from Allen Bradley PLC, i need someone to help me elaborate more on this uploaded project
will appreciate any help thanks
If you don't have any electrical prints or documentation, you better start mapping.
This will be time consuming, and only you will be able to figure it out. This type of thing cant be done over the internet.
I would recommend finding a reputable electronics repair shop to see if perhaps they can take a look at and repair the HMI. Perhaps reach out to your local AB distributor.
Long road ahead most likely.
Hi, thanks for the reply
the main board of the HMI needs to be replaced. this is as good as buying new HMI. Coz after replacing the board it becomes blank. bringing you to the same task.
I agree with the others. A full reverse engineering effort is quite an undertaking.
Now, IF the PLC program could be de-coded (and it surely can (*) ), then, the Panelview Function could similarly be de-coded, again, without too much precision.
But, at some point, you will need information as to what is actually connected to the hardwired I/O points, both digital and analog.
Like the other have stated, without prior system documentation, this is a long and error prone task. All you need is to have two signals swapped, and you might mis-label a button, or mis-calculate a variable.
On-site work.
Hi, thanks for the reply.
am putting more effort to see that i go through with this project. indeed is a challenging one. but contributions from this forum remain my strength
once more thanks
If a programmable controller controls the operation of a motor, what connects motor control to the PC? A) Line voltage B) I/O device C) Modem D)...
27
7,101
Hi all, Am new here, normally I work on OSAI and Beckhoff systems but I have a problem with some Indramat dkc11.3 drives that all display the...
1,421
i have a project that i need help designing. i go to college but we only get 2 hours a week to work on the computer that has the plc program. i...
2,413
Hi Friends ! I'm having a little challenge here, I'm almost done in my conversion project from panelBuilder to Factory Talk. I really need a...
1,579
Rockwell Migration guide did not state any action for the correction of below error: Screen 4 - 82PK961C_D: Message display object will be...
1,812
