Best option for PC in industrial environment
electro89
Mar 2012
Canada
106
Looking at installing 5 PCs around a plant to each run a session of Ignition. The environment will be dusty with some vibration, so fanless and SSDs will be used. I'm looking at Advantech and OnLogic (or Logic Supply) as options, but are these any more or less reliable than an office-grade Lenovo PC?
As a general question regarding all options, is OS corruption a common issue when dealing with full PCs? What's the best way to prepare for this or prevent it from happening? In the past I've only done this type of application with thin clients and rdp to a server, so this is somewhat new to me.
Any other issues I should be prepared for with this setup based on your experiences?
As for monitors, I was looking at Advantech's panel mount 19" non-touch monitors. They seem to be the best price I could find, but are they good quality? I've seen a lot of people recommend Hope Industrial. More expensive, but they seem to be a favourite.
Thanks in advance!
As long as it is running on Windows Embedded/IoT then it should be fine. Just make sure that you can install Ignition on it...
For Industrial PCs, I would always consider Beckhoff. They have been working on the minute details of reliable industrial PCs since the early 80s.
Beckhoff Automation has been doing Industrial PCs since the early 80's, whereas Advantech's founding is undoubtably in the Embedded world.
Make sure you either use a seperate UPS or get a controller with a built in supercap so that it can finish any writes and shutdown gracefully. Sure for a PLC application the 1sec UPS is enough to finish writing, maybe send out a last will and testament - but you might want a little bit longer for a SCADA system. Depends what he's doing. Worth looking into though, as the supercap is more reliable than a UPS.
There are other things you can do, like disallow write to the OS partition at all, and just have a separate storage device for the application. Have a repository somewhere on the network that you can hit a button and get up and running again. Should be rare if you use the right gear.
The main reason for corruption of OS images is not necessarily power cuts, but power dips or power spikes. UPS or capacitor helps, put the power supply component of the PC is important to. Say you have a home power supply, it might allow the system to run with a voltage just high enough that it runs, but also low enough that a bit juuuust doesn't quite get set when it's supposed to. I suspect 95% of the cases of raspberry OS corruptions one hears about are undervoltage related, either from using the 0.5A charger that came with your phone 5 years ago that was in the drawer, or for adding too many peripherals.
I would say yes, Industrial PCs are more reliable than a lenovo for sure.
Out of interest, are these just Ignition Clients, or Ignition Edge Gateways too?
I should have specified, these will all be communicating to an ignition server installed on a server grade machine, which will definitely have a UPS on the power supply. The server will be handling the comms and code. Not sure if this affects your response. I will definitely have a look into super caps tomorrow. Never knew something like that existed. I usually just purchase apc ups’s when I need voltage regulation. Could you recommend a brand?
And yes these are just ignition clients, not edge gateways
Hi all, I need to bring in a single AI (temperature) from a remote location (2 miles) into a Controllogix PLC. Any simple cheap suggestions...
18
964
According to your experience, what is the best database to use in Datalogs? Historian sucks. A ultra expensive software, a real headache. Too...
1,405
so im trying to figure out a little setup in my head for a machine and im looking for some advice. im using a micrologix 1400 so i figured i could...
4,492
I currently have an associates in industrial technology which included 3 semesters of PLC programming. Those 3 semesters got me a certificate for...
5,851
I need to know what kind of limit switch would fit my application. I need to sense whenever a pipe comes to a transference station, so that a...
1,665
