Siemens Programmer Cables
RUSKIE
Mar 2005
Hello all,
I have just acquired an old Siemens PG720 programmer with "Step5" installed, it's fully functional except that the COM/TTY to 15PIN-IF connection cable (6ES5734-2BD20) is missing, I have several PC/RS232 to AG/TTY 15PIN cables (6ES5734-1BD20) which are used on "PC" programmers, can I use one of these for "Step5" programming with the PG720 or can I convert it to operate the same way, I.E. by changing the wires internally or with a "breakout" box.
Your feedback would be greatly appreciated,
RUSKIE
I dont know if the -1BD20 cable can be used with a PG.
I have found the pinout for the -2BD20 cable, maybe that can help you:
Thanks Aslan,
For the attachment, but I think it does the same job as the "PC" programmer cables i've got - (6ES5 734-1BD20 which makes the PC/RS232 to AG/TTY into a current loop interface.
Ruskie
Ruskie,
I have just had a peek at our old PG720P. It has two serial ports COM1 - 25 pins, and COM2 - 9 pins. Theoretically you should be able to attach the -1BD20 cable to COM2.
But the problem is that I cannot see how to instruct STEP5 to use COM2 and not COM1.
If you are bold enough (!), you could just try to attach the -1BD20 cable to COM1 and see how it goes. ;)
JesperMP,
That idea of yours - using the COM2-9pin port I feel would work, but like you, how do you configure Step5 to use it.
As to using the 6ES5 734-1BD20 cable in COM1, I don't think so, mainly because I have just found out that the 1BD20 is a converter cable with internally generated current loop circuitry to mimic the PG720 COM1 port. Ruskie
Thats right, but maybe the 2BD20 cable connects to some of the "lesser popular" pins in the 25 pin COM1 port of the PG. So, when the 1BD20 cable connects to the "regular" Txd and Rxd pins in the 25 pin COM1 port, everything will work just fine.
Its just speculation. A little detective work (maybe by you, eh ?) can get to the bottom of this mystery :)
I like the spirit - run the risk of making the wrong cable - or have the right cable for the job , for the cost of a stamp -
Which one to choose?
Fred Floggle,
I bottled out!, I'll Take up your offer.
Ruskie
I've recently been on some official Siemens training and I'm planning to attain certification in programming TIA Portal as soon as I can talk my...
25
6,271
Just curious if anyone could recommend a PLC programming company in this area, or provide contact info? Specifically for Siemens control...
1,782
Wish you all A happy Year ... i want to ask about SIEMENS S7 certified programmer , is it an exam to take .. ? does it require courses before the...
6,051
Hi PLCS.net, I'm currently looking for Siemens LOGO programmer/ or training center in Singapore. Kindly let me know, thank you!
1,632
I have a customer and Louisville Kentucky it's looking for some Siemens S5 help. They need to upload a program to troubleshoot why it will not...
22
6,605
