This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Guest
Posts: n/a
Hi, does anyone know what a wiring diagram of a 240V power supply to a plc and pump looks like?
#2 |
come on, roll up - who is gonna say YES I DO
#3 |
Guest
Posts: n/a
What i SHOULD have said is can someone please SHOW me what one looks like...
#4 |
![]() Join Date: Feb 2005
wrong again use capital letters for PLEASE not for SHOW.
#5 |
I dont but I can offer some things to help get started
If you read some plc manuals and starter manuals you can determine how the wiring could be done. I offer these pictures to help you get started.
This is a generic starter that is using a DC power supply for the control wiring. ![]() This is an AD DL05 generic wiring scenario.
__________________
http://www.patchn.com Industrial Electrical & Maintenance @ www.patchn.com "Tell me and I forget, show me and I remember, involve me and I understand." |
#6 |
![]() Join Date: Sep 2003
Why would you give this spamming asswipe what he is asking for, especially when it's answers to his homework?
#7 |
I am not here to judge
First and foremost I did not give a diagram for a plc and a pump. I offered examples for the basics.
I provide this info because it helps me maintain and/or advance what I know about certain things. So, its homework, reading a book or reading a message on a forum is different? The idea is to learn, where better than those that are experienced in the field? I offer simple things like this everyday..Example: http://www.patchn.com/electrical.htm HAS
__________________
#8 |
rsdoran, I don't mean to be picky because I think you do an awesome site, but I want my controls at a lower voltage (prefer 24 VDC or max 120 VAC). No line voltage for pushbuttons especially if the system is 480 VAC. I know you know this because I have seen what you do at patchn.com, just don't want some idiot to kill themselves (or someone else) because they saw something on the internet and are now experts at it. Some of these people (read students) don't seem to be learning anything at all, just getting everyone else to do there work for them. The day they get a real job and have someone hook up a motor circuit "just like they saw on the internet" is the day that some poor unsuspecting soul will get hurt or die. Again please don't take this as criticism, just look at this as a footnote to the circuit.
#9 |
If you noticed the first picture used a DC power supply for the control circuit, either a 120vac or 24vdc supply is standard especially when a plc is involved.
Also note that the picture above is in no way improper or incorrect. To this day many systems are wired direct with supply voltage. I also dont care for this method but it is acceptable.
__________________
#10 |
I guess I DO
There was such an overwhelming response to my posts that I thought I should expand on my previous diagrams. Attached is a pdf file with a plc, hydraulic pump and spindle motor diagram.
__________________
#11 | |
![]() Join Date: May 2003
Quote:
Phrases that are used to hide ignorance: "It's too complicated to explain." Translation: I don't really understand how it works. "That's not covered in this class." Translation: Can mean exactly what it says, but usually means "I don't really understand how it works." "Don't worry about it. You'll never use it." Translation: You'll never use it because I can't explain it, because I don't really understand how it works.
#12 | |
Each and every post here is from people that may be students, hobbyists or work in different fields of automation, electrical, maintenance etc.
Many questions are improperly or poorly phrased, this one being a good example. Quote:
The odds of me offering a drawing that exactly matches the needs for this post or any student post similar would be high. In most cases what I offer is just generic/basic drawings that can be obtained from many sources. We are a RESOURCE. PLC.net, mrplc.com, patchn.com, ifps.org and the list goes on. WHO better to inform the "students" of today on HOW to for any subject? My motives for answering these questions are basically selfish, the more I answer the more I learn. I have also gained in the ability to explain to others. There are some areas that I can easily provide info and explanations for. There are others that I can provide info but the explanation will be weak. There are also the areas I dont have a clue about, which by far are more numerous then the first 2. I will continue to provide information, pictures etc when I can AND want too.
__________________
#13 |
Ron,
Keep up the good work. The lurkers here appreciate your efforts. We are all students until we quit wanting to learn. Brian. |
#14 | |
Quote:
First he started this thread, which he bumped a number of times. When he didn't get the answers he wanted, he posted a bunch of **** like this Thread and this one. He then logged off and started re-posted his original question as a guest (this very thread) That kind of behavior is absured. The best kind of response that I can think of (short of banning his IP address) is just to ignore him. I'm certainly not going to do him any favors, even if the teaching exercise may help me a little. I guess what i'm trying to say is that condoning and fostering that kind of childish behavior is likely to make things worse in ways that can't be offset by the gains in understanding that I may get by teaching something. |
#15 |
I didn't realize this was the "poo guy" (as I referred to him in my head).
Had I, I would not have posted to this troll's thread at all. How were we supposed to know this was the same guy? I never saw the first post, so never saw this question... Once I saw the "poo posts," I stopped clicking on his threads altogether. Last edited by DonsDaMan; March 31st, 2005 at 05:34 PM. |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| RE : SLC-5/04 no power supply to processor | patten | LIVE PLC Questions And Answers | 5 | January 7th, 2005 01:13 PM |
| Redundant Power SUpply for SLC 500? Sound weird! | ckchew666 | LIVE PLC Questions And Answers | 3 | November 23rd, 2004 06:48 AM |
| To Latch Or Not To Latch | BOWRIDER | LIVE PLC Questions And Answers | 36 | November 6th, 2004 04:30 PM |
| slc 500 power supply problem | medo | LIVE PLC Questions And Answers | 5 | June 1st, 2004 08:05 PM |
| Switching vs. linear power supply for PLC I/O | PhilRey | LIVE PLC Questions And Answers | 2 | July 26th, 2002 06:05 PM |
