plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old October 11th, 2005, 02:33 AM   #1
John Gaunt
Australia
John Gaunt is offline
John Gaunt's Avatar
Arrow Converting from S5 to S7
I have been asked to look into replacing four existing S5 PLC's
with four new S7-300 PLC's.
I have some files which I am told are the program.
The program was originally written by a company in Germany that
no longer exists. I assume it is written in S5 Statement List
with some comments but all in German.
I have Step7 V5.3 but nothing for programming S5
I have several questions.
1. How can I obtain S5 programming tools?
2. How can I look at the S5 code?
3. Can I somehow import this code into Step7 V5.3?
4. Can I convert this code automatically into S7 code?
Regards...............John Gaunt
Old October 11th, 2005, 02:46 AM   #2
jvdcande
Belgium
jvdcande is offline
jvdcande's Avatar
John,
I'll try to answer all of your questions.
A good tool could be S5 for Windows. Because you don't need it over a longer period of time, you'll probably find the demo sufficient. This software uses a different format to store the S5 programs, but you can import and import Siemens style Step5 files without any problem.
Well yes. There is a tool in the STEP7 package called 'Converting S5 Files'. I have found that this tool can translate about 80% of the programs I have used automatically. If not everything is translated, the tools gives guidance on how to fix it manually. Only a small number of instructions has no translation or no tips on how to translate to S7.
I hope this info will get you on your way. Good luck with the translation.
Kind regards,
__________________
Jean Pierre Vandecandelaere
Professional expert industry
VDAB Hoofdbestuur
Gasthuisstraat 31 - 10e verd
B-1000 Brussel
Belgium
Old October 11th, 2005, 02:53 AM   #3
PLucas
England
PLucas is offline
PLucas's Avatar
John,
In answer to one your questions..
2. Ask some kindly sole who has Step5 to print out the program to a text file for you, or even to a PDF file for you.
I did edit this message as I see Jean Pierre answered while I was busy typing, so rather than duplicate the answer he has given, I just gave you one answer
Paul
__________________
There are 10 types of people in this world..
Those who understand binary and those who don't!
Old October 11th, 2005, 05:02 PM   #4
John Gaunt
Australia
John Gaunt's Avatar
Arrow
Thanks jvdcande and PLucas for your posts,
I will try to find somebody with the S5 programming tools.
jvdcande - I tried to download "S5 for Windows" but was unable
to find exactly that name. I downloaded "S5 S7DEMO ENG.exe"
but got a message saying it was not executable (PC is XP PRO)
Did I pick the wrong download?
Regards............John Gaunt
Old October 11th, 2005, 05:27 PM   #5
Eric Nelson
United States
Eric Nelson is offline
Eric Nelson's Avatar
Quote:
Originally Posted by John Gaunt
jvdcande - I tried to download "S5 for Windows" but was unable to find exactly that name. I downloaded "S5 S7DEMO ENG.exe"
That's the correct program. I just tried it myself on my laptop with XP Pro and it works fine. The file you download is a self-extracting zip file. You can extract it with Winzip if you prefer.
-Eric
Old October 11th, 2005, 11:44 PM   #6
Krish
Australia
Krish is offline
Quote:
Originally Posted by jvdcande
John,
Kind regards,
Is this function available in Simatic manager. If so where can I find it
Thank you
Old October 11th, 2005, 11:56 PM   #7
PLucas
England
PLucas is offline
PLucas's Avatar
Thank you
Krish
Converting S5 to S7 is part of the Simatic software.
Select Start->Simatic->Step7->Converting S5 Files
Paul
__________________
Old October 12th, 2005, 03:14 AM   #8
John Gaunt
Australia
John Gaunt's Avatar
Arrow S5 to S7
Thanks Eric Nelson,
I downloaded it again - This time it worked fine.
Regards..............John Gaunt
Old October 12th, 2005, 03:52 AM   #9
Krish
Australia
Krish is offline
Thanx PLucas
Old October 12th, 2005, 02:14 PM   #10
jvdcande
Belgium
jvdcande is offline
jvdcande's Avatar
Hello guys? Sorry I didn't reply to the questions directed at me, but I have been away for a seminar all day. My fingers are itching like hell because I didn't touch a keyboard all day long.
Eric and Paul: many, many thanks for taking over.
Kind regards,
__________________
VDAB Hoofdbestuur
B-1000 Brussel
Belgium
Old October 12th, 2005, 10:42 PM   #11
John Gaunt
Australia
John Gaunt's Avatar
Arrow S5 to S7 conversion
I now have a pdf of the S5 program (via Siemens contact in Singapore).
I have tried the Step7 S5 to S7 conversion which comes up with
a lot of warnings but only about 6 errors.
Now I don't know what changes to make to fix the errors but
can try using trial and error.
However, more importantly I haven't found in S5 to S7 conversion
(or elsewhere) some means to make the changes either to the
original S5 program or to the S7 conversion.
I have tried S5 S7 for windows but it seems to find more problems
than the Siemens S5 to S7 conversion.
Can somebody guide me in the right direction?
Old October 13th, 2005, 12:35 AM   #12
David.F
Australia
David.F is offline
John, depending on where you are in Tasmania there is a Siemens Solution Provider with offices in Hobart & Launceston who might be able to save you a heck of a lot of heartache
Regards, Dave
Old October 13th, 2005, 04:14 AM   #13
RolfB
Germany
RolfB is offline
Hi John,
after doing the conversion, create a new
projekt in S7. Go to 'S7-Program-Sources' and
choose 'insert a new object'--> external source.
Choose the file which you have converted (???.awl)
Doubleclick on it and you are in the editor.
Click on 'File --> compile. You'll get an errorlist.
For more details download the manual at this link:
http://support.automation.siemens.co...&objid=1118413
cheers
Rolf
Old October 13th, 2005, 05:11 PM   #14
John Gaunt
Australia
John Gaunt's Avatar
Arrow S5 to S7 Conversion
Thanks David.F,
I will contact the company you refer to.
Thanks RolfB
I will give that a try.
Regards..........John Gaunt
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
COnverting S5 Real (KG) to S7 Real smersh LIVE PLC Questions And Answers 9 August 8th, 2011 09:53 AM
Siemens S5 and S7 Dual Masters for Profibus daveswerld LIVE PLC Questions And Answers 15 December 16th, 2008 02:15 AM
converting s5 to s7 mrsenolsezer LIVE PLC Questions And Answers 6 December 21st, 2004 09:44 AM
Converting S5 programs to S7 zezito LIVE PLC Questions And Answers 1 September 24th, 2004 08:33 AM
Converting TI (S5) programs to S7 tenerowicz LIVE PLC Questions And Answers 3 March 19th, 2004 08:19 AM
