We have had a couple of good motion control post the last couple of weeks. I have not been much help but I have enjoyed reading them.
So here is my question. What do you do when you need more than 8 axis? I am using a Delta RMC100 controller that has a max of 8 axis. I can use two controllers but if I want to gear an axis on one to an axis on the other what is the best solution?
Solution 1:
From the PLC start the moves at the same time at the same rate.
Solution 2:
Feed both controllers with a position reference from the master axis. This could be done with an analog feedback easy but I am using SSI. To stay with SSI I would have to use two position sensors.
Solution 3:
Get Peter to make a controller with more than 8 axis.
Any other solutions?
Solution 1:
Solution 2:
Solution 3:
