bwwestbrook
I am trying to communicate with a Taptone (T500) that has an RS232 serial port only. What would be the best way to convert this to ethernet and be able to pull information from it using a controllogix processor?
Below is some advice for Taptone, but they weren't able to give me much hardware or PLC advice.
The T500 X-Ray machine supports a single command to output the counter information to the RS232 serial port. The request for this counter list output is "1.0" in ASCII text.
The machine will look for the 3 ASCII characters, 1.0, and respond with the following list: (x's indicate data in the response)
TapTone 500 - Ver x.x
Container Inspection System
(c) 1999 TapTone/Benthos
Product Type = x
Total = x
Pass = x
Fail = x
Rej 1 = x
Rej 2 = x
Sensor2 Underfill = x
Sensor 2 Overfill = x
Input #1 = x
Input #2 = x
Input #3 = x
Input #4 = x
Input #5 = x
Input #6 = x
Input #7 = x
Note: The serial port runs at: 9600 baud, 8 data bit, 1 stop bit, no parity.
Product Type = x
Total = x
Pass = x
Fail = x
Rej 1 = x
Rej 2 = x
Input #1 = x
Input #2 = x
Input #3 = x
Input #4 = x
Input #5 = x
Input #6 = x
Input #7 = x
