Siemens Starter upload download
Kataeb
Jan 2007
www.livelovelebanon.com
636
Dear Sirs,
We have 10 drives micromaster 440 on our machine. These drives are commissioned using the starter software (V4.0.1.0).
The parameters of the first drive are uploaded to the PG. How can we download these parameters to the other 9 drives? (same program should be on all drives)
Kindly, check attached file.
Best regards
If you have a BOP for one of them, and if not they are easy to acquire, then there is a simple cloning feature. It is in the user's manual for the BOP (Basic Operator Panel)
Oh, I'm not sure how to do it with Drive Starter. Drive Monitor is a very similiar program and there is an upload download option under file. You can upload from one and download that to another one. I'm sure there is a similiar function. Sorry I couldn't be more help.
Oh, you'll want to upload the program using Starter, then make copies of it and edit each copy so it has the right Profibus address. Then you can download the program easily to each drive using Starter. I did it that way for a system with about 30 drives, plus used Simocode ES to do the same for the 100 motor starters using Simocode Pros. Very quick and easy. However, note that routing won't work through a CP342-5, only though the Profibus port onboard the CPU. The CP342-5 only supports Profibus V0 (cyclic)
RichWargo said:
Oh, you'll want to upload the program using Starter, then make copies of it and edit each copy so it has the right Profibus address. Then you can download the program easily to each drive using Starter. I did it that way for a system with about 30 drives. Very quick and easy.
how did you do it? was it micromaster drives?
We've been using MicroMaster drives, starting to recommend Sinamics drives. We always set the Profibus address using the dipswitches on the Profibus adapter, plus set the address in the software using BOP.
I second the above.
Use the BOP and do a "quick Commissioning" of each drive in which you set the Profi Address as well as a couple of other parameters (P600 or P900 range for your address on the MicroMaster, beena while).
Once done with the Quick Commissioning cycle power to the drive and then use Starter as stated above, make copies of one file and change the address on each file to match your drives. After the initial upload/download If you do an upload/donwload with the correct address you will upload/download changes done to the individual drive.
bkottaras said:
I second the above.
"cycle power": means turn power off then on?
"make copies of one file": i could not find the uploaded file in starter (like we do in drive monitor). where is it? how can i copy it? or see its contents?
Yes as OFF then ON.
Files may be stored in the default directory where starter is installed.
Or some other folder, not sure how they setup originally.
But, if you know the Profibus aaddress of your drives, you can upload using starter and create new files for each one of them then store them in someplace where you can find them in the future.
I need to change a parameter to a drive in Starter. I know just enough about Starter to get me in trouble. Is this correct procedure.... When...
1,595
Hi, I am interested in buying a Siemens starter kit. I came across this site, realpars.com Does anyone know if this is a reputable company?? Any...
1,190
Hi All, I have a Simens CU320 drive controller that I wish to connect to via the X127 ethernet port. The unit communicates with the CPU vua...
4,143
Hello, I have connected ethernet cable with my laptop and the s120 control unit. setup my laptop ip 169.254.11.1 and subnet mast 255.255.0.0 ...
20
5,643
I would like to do an auto tune on a Siemens drive in an existing project in Starter. I have looked at the manuals and some videos but most...
2,079
