Siemens Starter Auto tune
Jim G.
Nov 2007
Georgia
187
I would like to do an auto tune on a Siemens drive in an existing project in Starter.
I have looked at the manuals and some videos but most everything wants to step through like I am beginning from scratch.
Does anyone have a step-by step procedure for doing this with an existing motor?
Hi if the project is already done, check the motor data and confront it with data on the motor badge.
go to service panel take priority, after make a stop measurement, and you are done.
I need to change a parameter to a drive in Starter. I know just enough about Starter to get me in trouble. Is this correct procedure.... When...
1,582
Hi, I am interested in buying a Siemens starter kit. I came across this site, realpars.com Does anyone know if this is a reputable company?? Any...
1,184
Hi All, I have a Simens CU320 drive controller that I wish to connect to via the X127 ethernet port. The unit communicates with the CPU vua...
4,099
Hello, I have connected ethernet cable with my laptop and the s120 control unit. setup my laptop ip 169.254.11.1 and subnet mast 255.255.0.0 ...
20
5,570
I need to make a parameter change on a drive using STARTER. I am using this for the first time so I want to make sure I am doing this right. I can...
1,598
