plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 21st, 2003, 07:01 PM   #1
jthornton
United States
jthornton is offline
jthornton's Avatar
Latch a Bit then Bit Shift Left
Ok after reading the help file it says that if you latch a bit u must unlatch it with an OTU instruction...
What I am doing is to turn on a bit (latch it) if the trigger is present then the next scan do a bit shift then latch etc. All seems to work well when the bit shift fires the original bit B10:0/0 unlatches itself which is what I want to happen and the next bit B10:0/1 is now a one ala the bit shift left.
"In the event of a power loss, any OTL controlled output device will energize with the return of power if the OTL bit was set when power was lost." I'm doing a FLL on the Bits for the Bit Shift Left on the first scan so it should take care of this I hope... gotta go and test this...
Am I missing anything here???
Will it explode in my face someday???
It works in testing...
[trigger]--[ons]---(BSL B10:0)
[trigger]----------(L B10:0/0)
AB SLC 5/03
Old August 21st, 2003, 10:59 PM   #2
Eric Nelson
United States
Eric Nelson is offline
Eric Nelson's Avatar
That should work fine. Since B10:0/0 is set by the latch, during a power loss it would be ON at powerup (if it WAS on before power went out), but you FILL will clear it out.
beerchug
-Eric
Old August 22nd, 2003, 07:35 AM   #3
jthornton
United States
jthornton's Avatar
Thanks for the validation.
John
beerchug
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
10 Bit Encoder Decoder/ GE90-30 Control Freak LIVE PLC Questions And Answers 6 July 12th, 2005 12:28 PM
Sequencing Using Bit Shift DoubleL LIVE PLC Questions And Answers 2 November 18th, 2004 12:38 PM
help using a bit shift left or right soup LIVE PLC Questions And Answers 6 March 5th, 2004 02:00 PM
Internal addresses rogerhollingsworth LIVE PLC Questions And Answers 5 August 10th, 2003 07:02 PM
RSLogix Bit Shift Left Question jthornton LIVE PLC Questions And Answers 7 August 17th, 2002 06:06 PM
