plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old October 10th, 2009, 03:07 PM   #1
rocket
South Africa
rocket is offline
Allen Bradley / RSLogix Dynamic Arrays
Hello
Is there any way to manipulate the length / number of members of an array in a program in runtime? I store time-stamped events in a buffer that get cleared again depending on age of each record and I do not want to pre-define the maximum size of the buffer (array) but rather let it grow and shrink dynamically as required (within reasonable limits of course). Is this possible and, if so, how?
Old October 10th, 2009, 04:48 PM   #2
bernie_carlton
United States
bernie_carlton is offline
bernie_carlton's Avatar
As far as I know for SLC, Micrologix, ControlLogix you will have to pre-assign some area for the maximum possible entries.
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old October 10th, 2009, 07:20 PM   #3
Operaghost
United States
Operaghost is offline
Operaghost's Avatar
Many instructions will allow you to vary the length (number of values it uses), but those locations must be created ahead of time and can not be added to or removed from memory while the controller is running.
OG
Old October 10th, 2009, 09:13 PM   #4
Peter Nachtwey
United States
Peter Nachtwey is offline
Peter Nachtwey's Avatar
Dynamic memory allocation is extremely difficult to do
Consider an array directly between two other data structures and you want to add more elements. A new array would need to be allocated of the new desired size and the data from the original array would then need to be copied to the new array. Now you have a hole that isn't used any more. This is called fragmentation. If you do this enough time the memory will not be able to allocate new data because there aren't any blocks big enough. Therefore memory would need to compressed ( garbage collection ). This would not be easy to do during a scan. Even allocating a new array would take time. Now all the code would need to be modified to point the new locations and this would need to happen on the fly.
I don't think you want your PLC slowing down like a Microsoft PC does when it gets short on memory.
__________________
"Living is easy with eyes closed, misunderstanding all you see...." Strawberry Fields Forever, John Lennon
Old October 11th, 2009, 01:02 AM   #5
rocket
South Africa
rocket is offline
OK thanks that is clear. BUT... I have created an AOI to do the timestamping when an input to it transitions high. In some applications, I only need say 10 timestamps, I flush out the oldest if more arrive. In other applications I need 100 or more. Now I don't particularly want to create separate AOI's for each type of use (i.e. one with an array of 10, one with 50, one with 100 etc.). I'd rather have one AOI and when calling it the first time, initialise the number of records required to buffer thereby sizing the array to the maximum required size. Is THIS possible?
Old October 11th, 2009, 01:18 AM   #6
(8{)} ( .)
Israel
(8{)} ( .) is offline
(8{)} ( .)'s Avatar
Dynamic arrays in PLCs
Hi Rocket.
I'm having a problem understanding your reasoning. Basically,
unless you're dealing with a crippling amount of memory
allocation I don't see a reason to save the 90 (or 50) entries.
Furthermore, I agree with Peter on this one. Dynamic memory
allocation is not (and perhaps shouldn't be) in a PLC's
vocabulary. If you really need it (which I don't think you do)
you should be looking at a coprocessor.
Good Luck,
(8{)} (: .)
(Yosi)
Old October 11th, 2009, 01:30 AM   #7
rocket
South Africa
rocket is offline
I time-stamp certain events in order to calculate how many times something has happened in an hour or in a day or even in a week or month. Depending on the duration and the nature of the process for which I'm time-stamping events, I need more or less "buffer" space.
I have created an Add-On-Instruction to capture and calculate the number of events in the desired time-frame.
I don't particularly like creating multiple AOI's for each type of scenario (i.e. one AOI that can capture up to 10 events and another that can handle 50). It simply seems a bit clumsy - and I would have liked to write my AOI such that when I use it in code I can then stipulate at first-call the maximum number of events it would need to handle... It's not so much a memory issue as an "elegance" issue. Why copy and past the exact same AOI when all that is different in the AOI is the maximum "buffer" size?
Old October 11th, 2009, 05:42 AM   #8
danny.michael
United States
danny.michael is offline
Could you not have maximum buffer size and beginning buffer location as inputs to the AOI?
Old October 28th, 2016, 12:50 PM   #9
abishur
United States
abishur is offline
Actually, this site
http://trutegra.com/different-array-...s-with-one-aoi
Shows a great method of creating a dynamic array inside of an AOI. I've tested it out by creating a shift left/right AOI
Old October 28th, 2016, 01:10 PM   #10
jkerekes
United States
jkerekes is offline
jkerekes's Avatar
Don't make the array part of the AOI. Make it an input/output parameter.
__________________
John
Old October 28th, 2016, 01:14 PM   #11
Paully's5.0
United States
Paully's5.0 is offline
Quote:
Originally Posted by abishur View Post
Actually, this site
Well that is interesting! +1 for learning something on a Friday.
Old October 28th, 2016, 01:18 PM   #12
RonJohn
United States
RonJohn is offline
RonJohn's Avatar
Actually, this site
+1. That looks pretty cool! Never saw this before, but I'll need to keep it in my back pocket.
Old November 7th, 2016, 01:36 AM   #13
rocket
South Africa
rocket is offline
Indeed thanks, that is how I've been doing it and it works well.
Old November 7th, 2016, 07:49 AM   #14
jstolaruk
United States
jstolaruk is offline
Actually, this site
I don't see how you believe this is dynamically creating arrays. The link shows how to get the size of an array passed to it by InOut reference using the SIZE instruction. That is not the same thing.
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen
Old November 7th, 2016, 08:02 AM   #15
rocket
South Africa
rocket is offline
Hi jstolaruk. Correct, it is not equivalent to dynamically creating arrays but it at least enables one to use a single AOI for arrays of varying sizes.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How To Enter Rslogix 5000???? sundar_scada LIVE PLC Questions And Answers 14 April 2nd, 2016 03:50 PM
Rockwell Allen Bradley Programming Software, RSLogix 5, RSLogix 500, RS Linx, RSLogix vvcd LIVE PLC Questions And Answers 21 September 24th, 2009 10:04 PM
Allen bradley RSLogix 5000 to siemens simocode steven_42 LIVE PLC Questions And Answers 3 July 7th, 2009 06:27 PM
RSLogix 5000 V15 Features Samneggs LIVE PLC Questions And Answers 18 April 20th, 2006 05:45 PM
Latest Allen Bradley Guardplc & Rslogix Guard!! ckchew666 LIVE PLC Questions And Answers 1 December 1st, 2003 01:49 AM
