argobamafan
I am adding to a current application and keep getting error code 9077 when i try to validate the changes I have made. I added a maintained push button with the tag address I:40/06 I can make it work by changing the address to I:41/06 or higher but I do not understand why it will not accept I:40/06. the error states. Error 9077 - Address overlaps Block Transfer/Pass-Through Control Byte
Problem
You entered a tag with the same address as the Block Transfer Control Byte. The Block Transfer control byte is always the lowest accessible byte in the discrete rack.
Solution
Do not assign this tag to an object. Re-assign the tag address. Disable block transfers, if used.
Problem
Solution
