KE Tech Member K Join Date Nov 2022 Location Kansas Posts 6 May 3, 2023 #1 Does anyone know where I could download panel builder 32 for old rockwell HMI's? Our supplier is no help and we are struggling to find the software. Thank you!
Operaghost Member Join Date Apr 2002 Location Dallas, TX USA Posts 4,107 May 3, 2023 #2 It is available on the RA download site if you have a toolkit. You might check with your local RA distributor (hopefully that isn't the supplier you referred to). If you are a good customer they might be able to set you up. OG
plvlce Lifetime Supporting Member P Join Date May 2017 Location Michigan Posts 1,074 May 3, 2023 #3 See technote QA55786: "no longer available for purchase since May 27 2022" If you have a valid serial number you can still download it, otherwise talk to your distributor as OG suggests.
