Cutler Hammer D50 for learning
tpankratz
Dec 2009
Montana
Hello all,
First time posting here. I am new to the PLC world and just know some very basics, but I would really like to learn more. The company I started working for has a bunch of PLC controled machines around and no one to troubleshoot our program without seeking outside assistance. A bunch of the machines are old Cutler Hammer D50s and a few newer Siemens S7-200s.
We have a handful of the D50 plcs laying around and I was wondering if they would be a good place to start learning? I realize that they are old but I think we actually have some programming software around for them. Should I try to do some project with one of them or should I try and find a newer PLC to learn on?
Also, does anyone know of any good beginner projects that I could do? Or would you recommend taking a course for learning? I already bought the PLC tutor book off of this site but I have a hard time just reading a book and learning, I need to do something hands on for it to really sink in. Suggestions?
The D50 is indeed an older plc. If you still have several in service, it is as good as any plc to learn on. You can certainly expect that some of the current operating units will be giving trouble soon as they approach their normal life expectancy. It would be a good idea at least to learn how to back up and restore the programming with the software. I may be wrong about this but I believe they have a battery in them. If they do, you should consider replacing the batteries before they go bad.
The software that I used was called WinGPC. I have a copy of a program that I used on a motor winding dip and bake oven if you need a working program for an example.
As far as learning goes, most plc makers all have different addressing numbers and schemes. There are a few different programming methods as well, such as ladder, structured text, and flow-chart.
I have a couple of these d50 plc's and tried testing them. I jumpered the 24v common to the common input line and then the 24v + to the input...
1,764
Where can I get this software I need it for work.
4,456
Hello, Does anyone know where I can find the DOS program GPC5 for a D50? I have this plc at work and need to backup. I tried using WINGPC v2.51...
3,429
I have a customer with several Cutler-Hammer D50s on their equipment. We are in the process of quoting an HMI addition, and are planning to use...
1,493
Hi there newbie with big problem. I have had a D50 fail and there is no replacement. I have found a Panasonic FP0 which has the same I/O but a...
3,546
