Siemens Module Information - Diagnostic Buffer
JOLTRON
Aug 2006
MI
692
I have been given code to put in a machine. I didn't write the code and there is quite a bit in german and STL which I'm not very comfortable with yet. When part of the code is run the PLC goes into stop mode. I get this info. I see where it tells me what FB is the problem, is there something that will tell me which network or line is the issue.
Event 1 of 500: Event ID 16# 4562
STOP caused by programming error (OB not loaded or not possible, or no FRB)
Breakpoint in user program: Cyclic program (OB1)
Priority class: 1
FB number: 1204
Module address: 65535
Previous operating mode: RUN
Requested operating mode: STOP (internal)
Internal error, Incoming event
01:30:16.066 PM 05/06/2010
Event 2 of 500: Event ID 16# 2523
Area length error when writing
Global DB, word access, Access address: 138
Requested OB: Programming error OB (OB121)
OB not found, or disabled, or cannot be started in the in the current operating mode
01:30:16.061 PM 05/06/2010
I'd say the issue is hardware or addressing. It looks like FB1204 is attempteng to address a module at diagnostic address 65535. If that module is offline or unavailable, and there's no information in OB81/82/83 to handle this error, it requests the CPU to go to STOP.
A missing or offline or mis-addressed module would also explain the "area length error when writing" in message #2.
FB1204 is writing to DBW138 in the currently open global DB, but the DB is not long enough. The I stack gives info on the currently open DB's etc.
Thanks for the info that helps a lot.
I just read up on the I stack last night but couldn't see it since I wasn't at the machine.
Hi! Doing a lab project with two 1214FC. Got a warning about reintegration of modules wasn´t configured and tried to do that. Found the two...
800
I have a 6ES7 421-7DH00-0AB0 card with the INTF LED illuminated red. This internal fault on the card is preventing the CPU from going into run...
1,105
On the Siemens IM153-1 Interface Module, ET200M, what is the difference between the "0 X-18/19/20" and the "1 x-8/9/10? Picture attached of the...
1,275
Any manufacture recommendation for remote I/O for Siemens PLC.
2,915
Hello, I am sending data from a siemens 319-3PN/DP Plc with a Additional Cp343-1 card from the Plc to a remote BNR pc. I have configured 2 tcp...
2,156
