plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 6th, 2012, 07:13 AM   #16
jseavers
United States
jseavers is offline
jseavers's Avatar
I have done this and it works great. We currently have many Fanuc Robots and Red Lion G3 HMI's communicating via Ethernet. First you have to make sure you have the HMI Option on your Robot.
From the Arctool Manual:
This manual is meant to be a supplement reference manual to the HMI Device Setup
and Operations Manual. This manual details the addressing and setup of system
variables for the R-J3iB Controller.
The R-J3iB controller communicates with the HMI device by using the R-J3iB
Controller as a GE Fanuc Series 90 PLC. Various data of the R-J3iB corresponds to
the address of Series 90 PLC. The HMI device accesses this data by accessing the
corresponding PLC address. This communication uses the SNPX communication
Protocol.
2. Accessing I/O ports (%I, %Q, %M %AI, %AQ)
The R-J3iB DI[1] can be accessed from HMI device as %Q1. Therefore, the R-J3iB I/O
ports correspond to the PLC address as follows:
R-J3iB I/O port PLC address Example
Digital input DI[x] %Qx DI[1] ⇔ %Q1
Digital output DO[x] %Ix DO[1] ⇔ %I1
Robot input RI[x] %Q(5000+x) RI[1] ⇔ %Q5001
Robot output RO[x] %I(5000+x) RO[1] ⇔ %I5001
UOP input UI[x] %Q(6000+x) UI[1] ⇔ %Q6001
UOP output UO[x] %I(6000+x) UO[1] ⇔ %I6001
SOP input SI[x] %Q(7000+x) SI[0] ⇔ %Q7000
SOP output SO[x] %I(7000+x) SO[0] ⇔ %I7000
Weld input WI[x] %Q(8000+x) WI[1] ⇔ %Q8001
Weld output WO[x] %I(8000+x) WO[1] ⇔ %I8001
Wire stick input WSI[x] %Q(8400+x) WSI[1] ⇔ %Q8401
Wire stick output WSO[x] %I(8400+x) WSO[1] ⇔ %I84001
Group input GI[x] %AQx GI[1] ⇔ %AQ1
Old November 6th, 2012, 07:25 AM   #17
edpg1
Canada
edpg1 is offline
Jseavers, thank you so much.
That's exactly what I needed, works like a charm.
Old November 6th, 2012, 09:51 AM   #18
Robodude
United States
Robodude is offline
For the PLC Access Driver within GE Machine Edition software, I used the GE TCPIP under View Native Driver/ GE Intelligent Platforms.
I needed SNPX for additional functionality of the HMI such as displaying alarm history and reading registers and robot status.
Assignments to robot registers, position registers, current posisiton, alarm history, program execution status and
system variables need to be set up through the system variable $SNPX_ASG
It seems in the fanuc controller, SNPX is not a physical interface but rather a software interface.
Old February 7th, 2017, 01:41 PM   #19
eagle_good
Brazil
eagle_good is offline
Hi friend....
I'm using GE's Proficy software and trying to read some internal registers of Fanuc RJ3iB .... via the GE TCPIP ethernet drive.
Please, could you please exemplify how I do this ....
** I checked and the Robot has the optional SNPX .... but...i don't know ...
** Why do I need the optional SNPx, if I'm going to use TCPIP?
** How is mapped the internal memory registers in RJ3ib ? That is, How the software Proficy sees these records ....
thank you so much
eagle_good
Old February 7th, 2017, 02:31 PM   #20
RussB
United States
RussB is offline
RussB's Avatar
What does this have to do with the OP of comms between a robot and a QuickPanel?
Quote:
Originally Posted by eagle_good View Post
Hi friend....
thank you so much
eagle_good
Proficy Machine Edition software is typically used to write PLC/PAC programs and QuickPanel or PC based HMI programs. As such they work well with many communication protocols.
~ Which of these are you writing with PME?
~ GE SNPx and SNP are serial protocols
~ The default Ethernet protocol for GE products is GE SRTP, does your robot have it installed?
~ You may also verify if the robot has EGD or Modbus TCP/IP
__________________
LEARN something today so you can TEACH something tomorrow.
DETAIL in your question promotes DETAIL in my answer.
Dominus Vobiscum <))>(
"Where is the wisdom that we have lost in knowledge?" T.S. Elliot
Old February 7th, 2017, 07:01 PM   #21
eagle_good
Brazil
Friend....
R: PC based HMI
R: Yes...but see this below of other poster...(previous posters)
Assignments to robot registers, position registers, current posisiton, alarm history, program execution status and system variables need to be set up through the system variable $SNPX_ASG, It seems in the fanuc controller, SNPX is not a physical interface but rather a software interface.
R: No,.... haven't it installed... however ... i am using GE TCPIP...
~ You may also verify if the robot has EGD or Modbus TCP/IP.
R: No .. I will not use this protocol, because I will use GE tcpip driver native.
Please... Reading the previous posters ,you will know about what we are talking ....
Eagle good
Old February 7th, 2017, 07:17 PM   #22
Steve Bailey
United States
Steve Bailey is offline
Steve Bailey's Avatar
Without trying to speak for him, I believe Russ is trying to tell you that you should have started a new thread instead of posting to one that is five years old. I agree.
GE and Fanuc dissolved their partnership at the end of 2012. There never was a partnership between GE and Fanuc robots, but Fanuc robot controllers and Fanuc CNC controllers share a lot of common technology.
In post #16, jseavers gave the mapping of the robot memory to GE Series 90 addresses.
Old February 7th, 2017, 07:33 PM   #23
eagle_good
Brazil
address register
Exactly Steve Bailey ..
The only thing I'm asking is the (offset) map of the memory map ..
Of RJ3ib conforme poster of 2012, of the jseavers.
What is the address of the register to accept them via software profice ?
since there is an offset
Our friend Robodude said that needs to use SNPX.
why ??
Sam eagle good
Old February 7th, 2017, 07:52 PM   #24
Steve Bailey
United States
My knowledge of Fanuc robots is limited. I know they are yellow. I know they share a lot of technology with Fanuc CNCs. I know their manuals are hard to follow.
Does your robot have the HMI option?
In your Proficy View PC target, you will need to add the GETCPIP driver. By default it will be given the name "Device1". You can rename it if you want. When you create a variable in the View target you must define it as "PLC Access" and specify that it is to use Device1. When you do that you must enter a PLC address for the variable. GE Series 90 memory designations are %I for discrete inputs, %Q for discrete outputs. %M for discrete internal memory bits, %AI for analog inputs. %AQ for analog outputs and %R for 16-bit register memory. 32-bit variables will use two consecutive %R addresses.
Old March 2nd, 2017, 08:20 PM   #25
eagle_good
Brazil
OK...
Steve Bailey
I'm trying to say the following ...
To access the UOPs, SOPs Group G [] has an offset.
But it is not possible to place this offset in the address of the variable box, since the offset (5000) is huge and exceeds the value allowed by the proficy software in the link box of the variable.
These offsets are not possible in proficy software.
How can I access this map below with these offset.?
Would you have an example to share?
Could you check if these offset are correct?
* hugs...
Old March 2nd, 2017, 08:55 PM   #26
Steve Bailey
United States
What address are you trying to enter that Proficy rejects?
Old March 3rd, 2017, 01:32 PM   #27
eagle_good
Brazil
adress offset rj3
Steve ... What’s up guy? How’s it goin’? ...
These below addresses are not supported by software Proficy Machine edition.
The offset is very high and the proficy address does not accept (and is limited to 2048).
but the digitais in/out really working....
what s software are you using?
hugs
Old December 7th, 2017, 03:25 PM   #28
RoTaTech
Canada
RoTaTech is offline
RoTaTech's Avatar
Thank you for this. I am currently connecting a Schneider HMI to a Fanuc R-30iB over Ethernet, and I thought I was going to have to use flags for all the UOPs.
__________________
"Nice mirror!" said Tom reflectively.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Fanuc robot mastering problem russrmartin LIVE PLC Questions And Answers 14 June 14th, 2012 08:50 AM
Fanuc Robot R-J2 M410iW PalletTool CPU Recovery OkiePC LIVE PLC Questions And Answers 5 November 29th, 2007 05:51 PM
Fanuc Robot, Devicenet, Turck - TRYING to make it all one happy family produktion LIVE PLC Questions And Answers 9 March 9th, 2007 06:53 AM
quickpanel to fanuc robot Scueter LIVE PLC Questions And Answers 2 February 10th, 2007 07:09 PM
Quickpanel to Fanuc robot Scueter LIVE PLC Questions And Answers 0 February 4th, 2007 12:11 AM
