TIA portal v11
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,342
So, "TIA Portal v11" must be just on the doorsteps right now.
There are several interesting presentations from the innovation tour here:
http://www.siemens.de/industry/automation/bayern/downloads/Seiten/Default.aspx
A couple of tidbits that I took note of:
T CPUs are not supported yet.
H CPUs are not supported yet.
Archives wont require a license on the panels.
The new comfort panels will be twice as performant as the multi panels (!).
Comfort panels will have an onboard viewer for PDF, Excel and Word (I can use that for my log-files).
System Diagnostics viewer on the comfort panels.
SCL debugging has been much improved.
They told us it should come this month for SUS. Also, there was that preview (innovation tour) that if you attended you get free half day training where you need your own computer with V11 installed, if i remember right, the training is in here fourth of may. So it cant be many days anymore.
Some other highlights
Indexed addressing like SCL variable[index] now also in ladder
Instead of several laddder boxes for addition and multiplication you can write a math formula directly in one ladder box.
Implicit data type conversion in SCL.
SCL suport for 1200 series CPU's.
They are also rumors about a new series of cpu's called 1500 series
Hopefully this software works from start! I still have nightmares from the time with WinCCFlexible 2004 :)
We received our V11 disk for innovation tour training today, no licence yet. V11 (SP1) with SUS should be next month.
The Tia Portal on tour in Sweden was suddenly postponed until autumn. Siemens said that the reason was that they wanted to ensure the best user experience. Wonder if best user experience means first service pack :)
Could be, I've forgotten the exact date we were told, but I believe it was late summer or early autumn (July / August).
since may first i'm going to the receiving departement to see if my SUS get shipped but nothing at this time
Glad to hear for the math ladder box like AB soft...It was a bit ugly to have multiple add instruction to add few variable...
I also seen the real "Undo" button !
For us it was not SUS delivery, it was delivered becouse of innovation tour training that requires you to have your computer with installed V11 when attending.
Hi all, I'm a bit of a noob with Siemens. (I know enough to be dangerous) I've come across a V11 offline program that doesn't match the online...
1,655
Hi, Yesterday I decided to try to download a program to device using my virtual machine which runs Windows 7 Professional and TIA PORTAL V11...
5,611
I am trying to get a tia portal v11 application to run and the software is telling me to install wincc basic v11 update 2 and wincc comfort v11...
4,118
I have a tia portal application programmed in ver 11, but when I try to open the application it says its missing v11 update 2, I downloaded and...
2,829
Hi all and Merry Christmas. I am running TIA Portal V11 with SP2 and UPDP5. I am only running 2 machines with this software right now and...
2,724
