Display Totalizer of Steam Flow Meter
Sunil Modi
Apr 2012
ahmedabad
Now I am using ABB plc.4-20 mA signal is coming from flow meter(E+H).I have already set 3000 kh/h rang in flow Meter for 20mA.Actual value of steam flow is display by SCALE function block but How I can calculate total flow of steam as a totalizer.
TOTAL (for some time period) = SUM (Flow Rates) over that time period.
What are the units "kh/h"? Did you mean kl/h (kiloliters per hour)?
For example, if your steam flow is measured in cubic meters per second (m^3/second), and you want to know the total volume of steam for the past 1 minute, then read the flow rate every second for 60 seconds, then add all of the 60 flow rates together to get steam volume (m^3) for 1 minute. For 1 hour, make 3600 readings and add together to find the steam cubic meters per hour.
On the other hand, your meter may have a built-in totalizer function that would be more accurate than creating your own totalizer in PLC logic.
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
129
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
173
Is there a way to add a local message display to Studio 5000 View Designer? If its there, I’m not finding it. I have used them in older versions...
410
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
146
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
109
