ControlLogix 5000 search function
realolman
Mar 2009
here
584
I have a difficult time finding inputs and outputs using CL5000 search.
Most of the time I am dealing with inputs and outputs and don't know anything about the tag names.
For example I just tried to find Local:2:O.Data.7 and I get nothing ... however scrolling thru the ladder logic there it is with a tag name of BlahBlahBlahSOlenoid25
How can I be sure I'm finding whats there? When I can't find stuff I KNOW is there it's kind of disconcerting.
thanks
When I get into a program that was written by others and I don't know the tag names that are associated (aliased or copied) I open the controller tags, find the I/O point, press right mouse button, and select "Got to cross-reference.....". That will open a window that will show everything related to that I/O point. What happens beyond that depends on the programmer. He could have directly aliased the tag or copied the data every scan into another tag.
I agree with jstolaruk.
You can also open your Find window and under "Limit To" select References to Tag. That will search for where the base tag is being referenced by an alias.
See, that I/O tag wasn't actually being used there. An alias was used there instead. In the 5000 system those are two separate tags. The alias "points" to the original I/O tag for the data, but it is still a separate tag.
The alias tag "knows" it is tied to the base I/O tag, but the I/O tag has no idea that there are aliases pointing to it.
OG
OG
Quite true, but the Cross-Reference tool does show this information.
Consider the situation in the picture attached. I created 2 tags, both aliased to the same input point. I ran the cross-reference on Tag1, and the resulting x-ref listing has "discovered" that the base tag for Tag1 has another tag associated with it, and lists that as well.
realolman's problem is that the BlahBlahBlahSOlenoid25 tag is an alias to the I/O point Local:2:O.Data.7, and a search will NOT find base tags, unless configured as above. The base tag for the alias is displayed on the ladder (if enabled), under the alias tag in blue with <> braces around it. This display is an RSLogix5000 function (i.e. the programming software), and the controller has nothing to do with it.
I'm attempting to read tags from a 1756L81E(FactoryTalk Logix Echo) controller using the PLC4J api. I have one read and one write bool setup in...
2,290
Hey All, I'm currently building a control system for a large building in a industrial setting. Doing lighting, vent, roof control, door access...
3,498
I know there's the DTOS Function, but I have a value of "35" that is really "0035", and that's how I want it converted. Looks like the function...
1,521
I am an Electric Engineer working as a maintenance engineer and manage some technician on the production hall now but in the past, I mostly focus...
3,553
I'm not a PLC programmer, so bear with me here ... I was making an AOI with a bunch of BOOL inputs and realized some of them were actually...
1,808
