plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 13th, 2002, 02:00 PM   #1
dollivier
United States
dollivier is offline
Din Rail Mount Toggle Switch
Does anyone know of a manufacturer that makes a DIN rail mount toggle switch? We need to provide a simple digital input that we want to keep inside the panel (away from happy fingers) and a DIN mount would be ideal for ease of installation.
Dennis
Old August 13th, 2002, 02:36 PM   #2
Greg Gauper
United States
Greg Gauper is offline
No, but you might be able to build something using a Universal 'empty' module from Phoenix Contact. They make empty module housings that are DIN rail mounted. I think the model series is 'UEGM'. Try Weidmuller as well.
Old August 13th, 2002, 03:42 PM   #3
rsdoran
United States
rsdoran is offline
rsdoran's Avatar
http://www.wielandinc.com/cat_5/toggle.htm
You didnt mention what kind of toggle and if I may ask why would you need this?
__________________
http://www.patchn.com Industrial Electrical & Maintenance @ www.patchn.com "Tell me and I forget, show me and I remember, involve me and I understand."
Old August 13th, 2002, 04:03 PM   #4
ROBO
United States
ROBO is offline
ROBO's Avatar
Allen-Bradely is the manufacturer. I oredered it from McMaster-Carr. Its good for 28VDC/2A or 120VAC/2A. The one I ordered is a on-off-on SPDT. McMaster-Carr part number is 7218K11. Cost is $23.37. Allen-Bradely part number is 1492-WD4P.
__________________
"I think it plugs in here."
Old August 13th, 2002, 04:06 PM   #5
ROBO
United States
ROBO is offline
ROBO's Avatar
Correction: McMaster-Carr number is 7218K13 not K11.
__________________
Old August 13th, 2002, 05:17 PM   #6
dollivier
United States
DIN Toggle Switch
The reason for the toggle: We have 2 available Modbus ports on the PLC. One is used to communicate via radio-modem to a SCADA computer running Wonderware. The other is used to communicate to a VFD to transfer a number of parameters / values to and from the PLC. To modify/troubleshoot using a laptop requires disconnecting the VFD communications. Since the PLC acts as the Modbus Master to the VFD and needs to be a Modbus Slave to the Laptop we will use the toggle switch to disable the transmit functions from the PLC when we must communicate with the laptop. A third Modbus port would be a great solution but this PLC, a Momentum, will not support a third Modbus port, per the factory tech support.
Old August 13th, 2002, 05:53 PM   #7
Terry Woods
United States
Terry Woods is offline
Ron,
As to what someone might need this for... see the tail-end of this thread...
http://www.plctalk.net/qanda/showthr...=&threadid=800
Old August 14th, 2002, 06:23 PM   #8
Manuel Raposo
Portugal
Manuel Raposo is offline
MURR Elektronic (Germany) has din rail modules with a relay and a switch which allowd us to select switch operation or relay operation.
__________________
Manuel Raposo
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Not PLC Related... DIN Rail Mount PushButton K.C. LIVE PLC Questions And Answers 24 October 23rd, 2007 08:13 PM
din mount UPS? g.robert LIVE PLC Questions And Answers 6 September 8th, 2004 12:38 PM
DIN Rail positioning godfrey LIVE PLC Questions And Answers 14 June 19th, 2004 09:26 PM
Toggle switch & Push button switch m_abd_el_khalik LIVE PLC Questions And Answers 4 November 2nd, 2003 09:51 AM
Toggle Switch askgaard LIVE PLC Questions And Answers 4 April 3rd, 2003 02:55 PM
