please help in citect scada
eng anmar
Mar 2015
iraq
hello every one :
am working in gas station and we r using PLC s7 300 with citect scada like picture below :
and every thing working good , But tody we add another tempreture sensor type TC k , and the work was successfull in PLC but in scada there is problem as below
in plc the tempreture output ok and we make actual test to see tempreture and make alarm and shutdown to engin and all ok and pass
but in scada on tempreture appear #BAD , for knowing my working in scada just make variable tag for output temp from PLC ( DB7,264 ) and put it after that in numeric number and make save and compile but stay #BAD
please help me if any think i miss
thanks
Mr GTUnit
already try this move but same result #BAD
for knowing we r using PSDirect driver and try make reload
is there move in this driver >> please help
Are there Max or Min limits on the data value and it's just out of range?
Try posting more pics of the the field configuration windows.
Post some pics of the working ones as well.
Besides mentioned solutions in previous posts, "###" can occur when you don't have good reading from device (for example to many packets have been lost).
What version of Citect.
how did you create the variable tag. Ie using the tag editor or in excel.
you could try a packing the project. Then setting the citect.INI OID parameter to 1 before compiling.
I believe the PS direct driver is a OPC driver so when compiling you need to reset the OID.
this pic that how i work on scada citect 7.20
FIRST : add variable tag as below
SECOND : make variable tag for alarm
THIRD : put the new variable tag for shutdown
after that make ### for tempreture
put the new variable tags in ### as below
and after that make save and compile and run
for note we r using psdirect and opc server , but we didnt make OID Reset because am afraid there will be problem as in help file below :
dear kellian
am already make packing but still same and for OID reset didnt make this move because i have flowmeters , MW , MWh and engin working hours , and am afraid to be deleted when i made this reset for OID
thanks for help
Sorry i forget something
when i make DB address in PLC the address for tempreture was DB7.DBD264
but in PSdirect driver i didnt add this address inside the driver and now it out of range of PSdirect as below
( there are many old address out of PSdirect driver range but its working as normal )
is that necessary ??
You may try to separate boolean data and real data in separate DB. With mix data type in same DB can lead to bad reading.
Hi i am by no means a cicode expert in fact i struggle with code. as a plant electrician i can do alarms, graphis, trends etc. i have citect...
1,436
I am trying to work out if I can connect Citect to a SLC5/04 with the following setup. SLC5/04 AIC+ (from 232 serial port on SLC5/04 to DH484...
2,294
please help me . I have to make this ladder diagram and I can’t figure it out :(
430
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
99
Hello, I am trying to get a Yokogawa Hart pressure Transmitter and a Rosemount Temp Transmitter to read on a 1769-IF4 module on an L33ERM...
411
