1756-ENBT and Power Over Ethernet Switch
scantime
Apr 2014
US
25
Has anyone had any experience using a 1756-ENBT card connected to a POE switch? All I have available to switch my Ethernet/IP connection from the 1756-ENBT card to other devices is a POE switch. I'm not sure if this will damage any AB devices, but I am wary of using it this way.
Contact Rockwell and ask them to be on the safe side. I have never used POE on control applications
Thanks..I chatted with Rockwell, they stated that there was an issue long ago but there wasn't a document saying that it wouldn't work. So while 2 negatives don't always make a positive, I went for it, and it's working fine. I Have a PV+1250 & 1756-ENBT on the POE switch.
Why not simply put power injectors in - not connecting the injected power part, and reverse them, between the PLC and the switch?
please using the usb can i assign any ip address that i want ?
151
Hi, I want to exchange data between two L55 PLCs using ENBT PLC1 is the main PLC and consist of 1756- CNB, L55 CPU and ENBT. Five remote I/O racks...
1,030
Hey guys, I'm not super familiar with Cnet, so I'd like some insight from people with more ControlNet experience than I. We have a controllogix...
893
I am looking into an ethernet drive network system using a Logix5000 system Version 20 and noticed that on the general tab of the properties of...
1,134
I wanted to confirm with the Gurus that a 1756-ENBT can not create raw sockets. I'm using Rockwells Process Library's T_Sync to connect to an NTP...
1,990
