1756-ENBT General IP Address
Dec 2011
North Carolina
I am looking into an ethernet drive network system using a Logix5000 system Version 20 and noticed that on the general tab of the properties of the 1756-ENBT card it was selected for a private network and the IP address of that selection is completely different from the actual port configuration of the card itself. Would this type configuration cause any issues on the network perhaps?
I don't think this will cause any issues. I have seen this before, the address configured on the card itself wins. Probably, the dip-switches on the ENBT are set to manually-configured address and not software-configured address so the Logix Designer/Logix 5000 PLC settings cannot overwrite the value.
The manual explains how this is done:
https://literature.rockwellautomation.com/idc/groups/literature/documents/um/enet-um006_-en-p.pdf
(Look up "Set the IP Address with Hardware Switches")
please using the usb can i assign any ip address that i want ?
151
Hi, I want to exchange data between two L55 PLCs using ENBT PLC1 is the main PLC and consist of 1756- CNB, L55 CPU and ENBT. Five remote I/O racks...
1,032
Hey guys, I'm not super familiar with Cnet, so I'd like some insight from people with more ControlNet experience than I. We have a controllogix...
896
I wanted to confirm with the Gurus that a 1756-ENBT can not create raw sockets. I'm using Rockwells Process Library's T_Sync to connect to an NTP...
1,994
My company has an AB 1756 PLC set including one 1756-ENBT module with static IP address. About two weeks ago the module began to stop working...
20
5,964
