0-10V Analog Input - Voltage not going all the way to 0
s205521
Oct 2007
KC, MO
We have a 4 wire 0-10V analog OPT2012 (Time of flight distance laser) from Wenglor that we're experimenting with. We are able to teach the laser at the 0V and 10V positions and the display on the laser shows the voltage output as expected. However, when we see the value on the plc input or even a multimeter, the lowest value only goes down to .14V. We don't use much analog so not sure if this would be expected to not have a true 0V input and thus requiring an offset. The module we are connecting to is a 5069-IY4. Thanks for any help!
i believe it is wired like this now.
+24v Power Supply --> Sensor +24v
24v Common Power Supply --> Sensor Common
0-10V Sensor output --> IY4 Input 0+
IY4 Input 0- --> 24v Common at PS
IY4 Input Common --> 24v Common at PS
I also have a 1769-IF4 in a test bench that I may try on Monday as a trial.
Perhaps sometimes we look for maximum accuracy in measuring devices that they really do not have.
If those 0.14V are within the measurement tolerance indicated in the device specifications, it should be considered acceptable.
Just asking for clarification here, but from my research all I need is a 500 ohm resistor across the AI and the common? Heres my schematic. I...
2,586
I am working with Fx2N-2DA and Fx0N-3A card ? what is the ladder logic for this two card ?
1,979
Hey guys were having difficulties with a flow meter that takes 24VDC PSU but sends 4-20ma output as we verified. The Compact Logix analog module...
17
10,691
Hi Friends, I have a LVDT for measurement of cylinder stock which output in resistance. How can I connect it to PLC's analog input? If is there...
2,287
I have a 10k Pot connected to a 0 to 10v Analog Input on a ControlLogix 5000 PLC. This Pot controls a conveyor speed. I need finer control of the...
4,906
