1-Phase VFD - Does it have to be derated?
skyfox
Nov 2006
CA
279
If a VFD is already classified for single phase input, does it still need to be de-rated? Will the motor(specs) shown below, work with the listed VFD specs or do I need to go with a VFD with higher Amp rating? Trying to avoid a step-up transformer and I haven't come across a VFD rated for higher amp rating than what is shown below that can work off a singe phase 115VAC supply.
Thanks.
it should work no derating necessary
from what I see it has a voltage doubler built in
120 1Ph supply with 230V 3Ph output to the motor
what band is it it looks like it may be Yaskawa
I think that’s a Weg part number.
But correct, no de-rating necessary because it is already rated for single phase input. 1-1/2 HP is the upper limit of 120V input, because beyond that the voltage doubler circuit becomes more expensive than a transformer.
Hi all. Will something like this work on a VFD output ? Carlo Gavazzi E83-2050 The VFD output frequency will be between 45-55 Hz. I know that its...
2,141
Hi all, Client with a pretty much brand new AB Powerflex VFD starting throwing Fault 17: Input Phase Loss this afternoon. Started doing some...
9,521
I know this has come up many times but I've yet to hear a good way to deal with the vfd issue. Here's where I am. I have a very old Haas milling...
31
12,108
I have been looking at a couple of power tools that have a 220v 3 phase motor. I was wanting to avoid having to install a rotary converter. But I...
2,231
Hi all, I'm in the search for a 1 phase in, 1 phase out VFD, 110 VAC, 1/4 hp. Any recommendations? It would be great if it has a keypad that can...
2,084
