High Leg 3 phase and vfd's
I believe you are correct and this was touched on earlier in the thread. The delta wye transformer fixed my original issue which I clearly didn't understand when I posted the original question.
On a job, not my milling machine and not my problem, but I'm looking at an isolation transformer which is delta wye. It clearly is connected wrong. Got me thinking about how I grounded my milling machine in this post. A few post before this one, I was asking about grounding issues I'm seeing in a plant that seem exactly relavent to the original post and important in my own shop.
Learned a lot in this thread. A little knowledge of grounding the said transformer would be great.
I know this thread is solved.
But here is some more info for reference.
On our asian milling machinery incoming voltage should be 200-210VAC for servos etc (FANUC)
I guess your haas is 460 incoming.
I always need to add 480delta>208/120wye transformer.
It seems you have figured this out.
Not really my problem, but my city has asked for help. They have two 15 hp 230V 3-phase motors pumping make up water into their water tower. The...
10,024
What is the US standard color coding of the high leg and other phases in a delta circuit? TIA This is what I have:
3,516
I work in a plant that has a High Leg Delta electric service, very old plant... we are having several VFD's tripping on bus overvoltage, across...
26
7,078
I have a 240, 3 phase High-Leg power feeding a control panel. Since there are heaters without Ground Fault Equipment Protection, there is a need...
3,499
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
124
